laugh.gifdoes your gf agree?
Whether it's a Virago or a 1098 the riding speaks for itself, anyone can go well on a 250, including a cruiser :thumbsup:
She won't even sit on a Virago :closedeyes:
I have nothing against Viragos :3
Buy one of those repsol hondas they look best
:thumbsup: Recent Fireblade is highly rated. Repsol paint scheme is the bomb.
He also had a yellow hyasong 650r thingo actually looked pretty good and they're LAMs approved aparently
If you're looking for low down torque in a 600/650 then V's or singles are the way to go and since the Hyosung is L plater friendly it would be a pretty good compromise. Tooth down on the front even one up on the rear and you'll have great acceleration, remove the cat with a slip on (if it hasn't been done already) to improve it even more. May sound like a muck around but you can do this pretty cheaply on the Hyo's.
They usually come reasonably cheap as well and if you buy second hand depreciation will be minimal. I would highly recommend test riding a few bikes at some dealers as it can make or break a bike and you don't want to regret it... I think you'd enjoy the Hyosung!
yeah think i'm just gonna go for the 650 hyasong even though its indian/korean or whatever. whats the point of their 250 model when it looks exactly the same as the 650, same size and both LAMS approved :/
All this bike talk, just buy one already :thumbsup:
you just mad coz no one's talking about fords
Depending on how it rides and second hand availability (none in vic currently) I'm keen to get one of these in June when I come back from o/s. Extremely good value for money. Though if I end up streetfightering my Blade I won't bother.
Edited by JEPPE
650 and just get a tune or something to derestrict it.. cops / insurance wont know
Guest
    • Hi guys, has anyone either purchased or built themselves a rotisserie for their car before? I can only just justify the need for one hence why I should just make one but at the same time, if I make one I can kiss another 4 weeks of potentially productive car working time goodbye because I'm building a bloody rotisserie....  I mainly want it for the application of the body deadener.  Cleaning the old stuff off, priming and then colour over the deadener doesn't worry me, it's just the application using the Schutz Gun that I feel would achieve a significantly better finish painting it side on and keeping the Schutz Gun upright.  I don't think they would work well on the side let alone almost upside down for some areas.  If the product I use (Terosun, etc) could work through a HVLP ok then it might be ok to apply without the rotisserie.   I can get one of these style ones for about $1200 which is pretty good value-     I reckon if I made one it would cost around $500 but it's more the time that it would take is more of a killer than the cost.  They look to hold their value pretty well second hand so I could always sell it after using it and realistically only lose $200-$300 at worst.  Or keep it and buy another project when this one finally sees the light of day... Anyone selling one...? Cheers!
    • While it is a very nice idea to put card style AFMs into the charge pipe (post intercooler, obviously), the position of the AFM and the recirc valve relative to each other starts to become something that you really have to consider. The situation: The stock AFM is located upstream the turbo, and the recirc valve return is located between the AFM and the turbo inlet, aimed at the turbo inlet, so that it flows away from and not through the AFM. Thus, once metered air is not metered again, neither flowing forwards, or backwards, when vented out of the charge pipe. When you put the AFM between the turbo outlet and the TB, there is a volume of pressurised charge pipe upstream of the AFM and there is a volume of pressurised pipe downstream of the AFM. When the recirc valve opens and vents the charge pipe, air is going to flow from both ends of the charge pipe towards the recirc valve. If the recirc valve is in the stock location, then the section between it and the TB doesn't really matter here - you're not going to try to put the AFM in that piece of pipe. But the AFM will likely be somewhere between the intercooler and the recirc valve, So the entire charge pipe volume from that position (upstream of the AFM, back through the intercooler, to the turbo outlet) is going to flow through the AFM, get registered as combustion air, cause the ECU to fuel for it, but get dumped out of the recirc valve and you will end up with a typical BOV related rich spike. So ideally you want to put the AFM as close to the TB as possible (so, just upstream of the crossover pipe, assuming that the stock crossover is still in use, or, just before the TB if an FFP is being used) and locate the recirc valve at the turbo outlet. Recirc valve at the turbo outlet is the new normal for things like EFRs anyway. In the even of a recirc valve opening dumping all the air in the charge pipe, pretty much all of it is going to go backwards, from the TB to the recirc valve near the turbo outlet. But only a small portion of it (that between the TB and the AFM) will pass through the AFM, and it will pass through going backwards. The card style AFMs are somewhat more immune to reading flow that passes through them in reverse than older AFMs are, so you should absolutely minimise the rich pulse behaviour associated with the unavoidable outcome of having both a recirc valve and an AFM in the charge pipe.
    • Yep, in my case as soon as I started hearing weird noises I backed off the tension until it sounded normal again. Delicate balance between enough tension to avoid that cold start slip and too much damaging things.
    • I'm almost at a point where I feel like changing the alternator. Need to check the stuff you mentioned first though.
