Haha your a banana!! We can push start it!! I don't have a battery charger.
jump started it should be right haha
It's called the divine power... Or commmonly known as discretion :P
Treat all members with respect and courtesy - We will ban any member(s) who make personal attacks, threats or mistreats any other member in anyway (discretion is up to the moderator at the time of the offence)
kunce never get banned for having a go at me :laugh:
Probably drinking with big brother.
that's cute
Lol. I'll probably be sleeping. It's just another day afterall
yet you celebrate meaningless weekends :rolleyes:
mate's holiday house in Loch Sport... lotta private roads down that way
who needs private roads when you can hit the waters with a jetski
I used rubber tap washers from Bunnings for that.
Actually I was talking about the metal bit not the spacers.
33 GTR have different way of mounting the plates - think 32 GTR is same.
welcome back funky where the fk ya been makin iphone 6?
lol funny you should mention. just got back from florida for a conference, and before that I was in SF visiting FB and Apple
at cass, you jelly?????
OMFGGGGGGG DUCK!
Ye they are sending them all over the place.
I was out the back @ the Euro workshop getting some cable tie modification, I don't think they were very used to that lol, and even he had one there :D
Gonna get a few of them for myself, they are quite awesome although i did notice a interesting addition to the HR31 lineup.
Guest
    • From the pictures I have when doing the job the flywheel is the same diameter, I don't think they're playing weird tricks like putting weights at the outer diameter to increase flywheel inertia or anything like that. The OEM flywheel is definitely heavier, but it's not a huge difference. Quoted weight savings of the clutch is 2 kg so I can't imagine the flywheel being lighter than ~7 kg. Kind of regret not weighing it before the clutch went into the car but as far as driveability goes I have no complaints.
    • HKS trigger kit should be very easy to integrate with a Link. It's a 36-2 crank trigger. Hard part is finding the motivation to take off the timing belt and everything on the front of the engine to install it. You also need to cut out a hole in the oil pump housing so the sensor can read the trigger wheel. Changing out the cam sensor for a 24 tooth setup is probably good enough but as others have mentioned depending on what underlying assumptions are changed it becomes more of a problem. Reading the crank state off of the cam is an abstraction that works in the general case, but if you have an edge case it makes less and less sense. There is a GTX2860 gen 2 that can take a compact 5 bolt housing so it's direct bolt on but I'm not 100% sure of what's involved. Peak compressor efficiency drops off a bit on these turbos vs -5s, 77% vs 73% but you get way, way wider region of operation. The -5s have a really strange surge line in their compressor map that is all over the place. If you think the hot side on the -5s aren't open enough you can try the Tomei T550B turbos which a local tuner seems to be happy with:
    • i need a complete tail light for my R33 GTR if you have please let me know.
    • I need a great maintenance workshop around Idaho, if you know one please let me know..
    • Hello friends, i have a good friend in Canada that looking for a good condition 1993 GTR around him please if one or know someone around you that is willing to let it go please let me know so that i can inform him.....Thanks
