yeh... i love when people post pics on forums of wrecked rims and there all like. "look how strong my genuine *insert jap brand here* rims are, i hit a gutter at 150pkh and they are only like 98% f**ked! i mean i still have to throw them out and buy new ones, but lucky they weren't fake rims cos then i'd have to throw them out and buy new ones"
:rolleyes:
Can I brag about my $1200 D1Rs lol? They are real!
Real/expensive lightweight wheels are what you put on a track car when you're trying to save every gram of weight from it because you've already done all you legally can to get power out of your engine. And 16kg is a LOT of weight to save on a track car, so then it's worth the $4k. I know people who remove useful bolts from their cars in an effort to save weight lol.
You also use real on the track because a lot of fakes or cheap wheels have balance issues at speed. Some, like my Lensos will shake/vibrate the wheel at 100km/h and there's nothing you can do to balance it...it's annoying but manageable on the street, so I'd go fakes every time, but that's me. Others will pay for a guarantee against these issues and it's not like they lose a huge deal of money on sought after pricey wheels.
So I guess higher priced, real wheels still come out on top :)
But I see your point.
yeah just replied, no PM notification on mobile :)
Cool thanks!
:rolleyes:
HAHAHAHAHHAHAHAHAH
Yo Aaron
Do you DJ at weddings?
If so, how much do ya charge?
I dont personally, but the other guy does. Its not as expensive as youd think but msg me later and ill be able to tell you.
f**k dj'ing at weddings... i did 1 and wanted to kill myself.
agree, but not for the same reason. Weddings are ALWAYS better with a Band usually a funk band. (not like the wedding singers)
I can probably organise that too if you wanted.
and here i am thinking about going for a vasectomy....
easier said than done,
most places don;t want to do it unless you already have kids or have a medical reason.
have to sit down with a counselor and shit b4 hand.
and if you just say cos I want to bang bitches and not worry won;t get you far!
the complications seem a little too drastic for that though..
lol.
but its not about banging bitches and not worrying. there's condoms for that. just felt i should terminate my line here, to do my part for overpopulation.
lol.
Hahaha you such a f**king moron hahahahah
Guest
    • Because that’s not what any of them are building these heads or blocks for. It’s to hold over over 1000hp at the wheels without breaking and none of that stuff is required to make power
    • Dort sounds above 3k rpm are dorty 🤣 I might krinkle black the alloy 🤔
    • It makes you wonder, all these people starting to make a billet replacement head, I wonder if any have thought about trying to adapt tech from newer engines into them. You're already at the full design stage to make a billet head... Why not really spice it up and had some more modern tech into the mix too...
    • Connect all the plumbing up properly. The actual worst part about having the turbo unable to actually build boost, is you can and likely would over soon the turbo if you drove the car (free rev while stationary isnt likely to manage it).   If you do have an air leak as Duncan suggested, you'll have a bad time as the AFM will be saying different to reality.   As you have had the engine out, I'd go over all electrical connections again. If you have a consult cable, plug it in, and see what the ECU thinks is going on. Did you touch the timing belt? If so, double check your timing on the gears is correct AND put a timing light on it while it's idling and see what ignition setting you have. Is the AFM you've installed the one that was in the car previously? You said you replaced seals, what seals exactly? What have you had apart?   From memory when I had my RB25DET with factory throttle, there was two plugs the TPS plug on the loom could go to. One would leave the car running like shit, the other made it work, I think one plug on the TPS area was for something else (an option). It's too many years since I saw that part of the loom to remember properly though.   Is the car idling smooth (as smooth as an RB can)? Does it smell fuelled up?   I have a feeling either timing in timing belt is off, or a sensor isn't right.
    • Theres still skid pan and motokhana days up in QLD at least that are $100 or less. The ones that are ran as "driver training" less so, they're expensive, but just normal skid pan days like SAU ran are still low cost. And thats one of the places I learned to be a lariken, purely by asking for passenger rides, and how people were doing crazy things. Reese gave me plenty of pointers back in the day for skid pan! And yes Duncan, I will never forget your pointers for track work. Especially after Neil got out saying "I am NEVER getting in the car with him again!" 😛
