Alex, got home tonight and saw one of your real estate agent signs buried in my garden
Pulled it out and then chucked it on the nature strip. Then realised a guy already asked my fiancée if he could put it there....:/
Lol. Fiancé should have known better :P
will I see your 34 up in carsales shortly?
Not till after le' wedding. At the rate prices are looking to have a wedding, could buy a couple of GTR's :/
Should have, don't mess with a man's front lawn brah
sneakily cut some expenses out of wedding!
buy gtr!
buy gtr!
What he said.
Or, elope and you'll have enough to buy a 34?
We'll I've been 'shopping' around and the cheapest decent place, just the 'venue & food' is already $30,000 :/
Though I was thinking of using GTR's as the grooms men's wedding cars for the day. Maybe you could help a brudda out since you seem to have acquired a nice one :D
30 grand?!
I'm sure Anthony would happy to drive you to the wedding if you ask him nicely.
As for me, when's the big day? I'm away for potentially 2 years - hurry up British Consulate!
You can have it at my house. 10k mates rates.
I'll even do a celebratory skid out the front (a big one)
30 grand?!
30G's to 55G's brah depending where I have it.
Ideally I was thinking white R35, R34, R33, R32. But don't think ill get that so beggars can't be choosers.
Big day is March next year.
hmm Manila or Hanoi next month...
Personally I didnt think there was much to do in Hanoi, but its been a few years since I've been there
Book me in! You can MC too brah
Haha yeh we don't use those permanent ones over here thankfully cos I cbf doing that shit!
An weddigs Fk oath massive rip! Hahah everything is 10 times standard price
im sure you would have some keys to holiday houses for sale? find a mansion in portsea, have wedding. winner winner chicken dinner.
lol finally you get a decent enough excuse to rent out some exotics and you wanna use nissans instead? :ermm:
Not gonna spend thousands of dollars hiring exotics brah.
Have seen White lamboghini gallardo's as wedding cars...Twas nice.... :whistling:
Got any vacant mansions Alex :D?
Guest
    • Got the motor out and torn down. I'll be dropping off the block Monday. Luckily the scoring on Cyl6 is much less pronounced then the pictures made it out to seem. It can barely be felt. If you pass your finger over it 10x you'll barely notice it. Hopefully by some chance it will only require a honing. I'm not in the mood to buy one size larger pistons or another block. Oddly enough my 6th cylinder with the scoring has extremely clean intake valves compared to my other 5 cylinders. I'm worried the scoring was caused by too much fuel or Water/Methanol washing the cylinder. I'll review some old logs to confirm.  This was also the first time I pull an engine with the transmission still attached. It went much better then expected. I was worried my CD009 wouldn't make it easy due to its sheer size but it was much easier this way.
    • From the pictures I have when doing the job the flywheel is the same diameter, I don't think they're playing weird tricks like putting weights at the outer diameter to increase flywheel inertia or anything like that. The OEM flywheel is definitely heavier, but it's not a huge difference. Quoted weight savings of the clutch is 2 kg so I can't imagine the flywheel being lighter than ~7 kg. Kind of regret not weighing it before the clutch went into the car but as far as driveability goes I have no complaints.
    • HKS trigger kit should be very easy to integrate with a Link. It's a 36-2 crank trigger. Hard part is finding the motivation to take off the timing belt and everything on the front of the engine to install it. You also need to cut out a hole in the oil pump housing so the sensor can read the trigger wheel. Changing out the cam sensor for a 24 tooth setup is probably good enough but as others have mentioned depending on what underlying assumptions are changed it becomes more of a problem. Reading the crank state off of the cam is an abstraction that works in the general case, but if you have an edge case it makes less and less sense. There is a GTX2860 gen 2 that can take a compact 5 bolt housing so it's direct bolt on but I'm not 100% sure of what's involved. Peak compressor efficiency drops off a bit on these turbos vs -5s, 77% vs 73% but you get way, way wider region of operation. The -5s have a really strange surge line in their compressor map that is all over the place. If you think the hot side on the -5s aren't open enough you can try the Tomei T550B turbos which a local tuner seems to be happy with:
    • i need a complete tail light for my R33 GTR if you have please let me know.
    • I need a great maintenance workshop around Idaho, if you know one please let me know..
