he's not in adelaide... wouldn't work
lol.
My GTR made 233rwkw on racepace dyno stock ish
2 weeks later went to a dyno day on furntree gully road, (GTCC one) and made 175awkw, :\
Then tuned with Trent + power FC made 260 on low boost
Goes to show you want to same dyno when testing
Get around mine, it's going to be mega
f**ken maso's
More boost you pussy
this and e85 = happy birds
Where's my invite Ric?
yeah mine too, maso brother :P
Gotta organise the bride first lol
thought that was being organised ;)
Says the Honda driver
that should tell you something
Hrmm just watched a mini trailer on the Herald Sun of a remake of Total Recall :/
Apparently has Colin Farell, Jessica Biel and Kate Beckinsale. Atleast there will be eye candy...
almost enough to save the travesty that this will turn out to be. almost
Okay.
In regards of finding someone to put the motor together and tune it.
My mate thinks I should go to a place that does everything in house, as I'm getting Sposaro to build up the engine and he's outsourcing the tuning to Creatd.
Mate recommends JPC.
They built his drag VL, and his 400kw Xr6.....
So cownfushun
Guest
    • Holy hell! That is absolutely stunning! Great work!!!
