whatever you do pick a workshop that provides an agreed warranty for the engine build
outlines the cost of the job and doesnt give you a surprise 2k extra bill at the end
and an agreed end date instead of "yeah soon" each month
Hmm
Who is it? Want someone who won't blow the engine up lol
Pm me brahhh... Might need to do 200kkm service soon
PM's sent
It's a specialised engine building workshop that does everything from street cars to full blown drag cars.
youre all wrong.
ric is half lebo, half black, half antarctican.
Nah, he is full HEKT1K.
Okay.
In regards of finding someone to put the motor together and tune it.
My mate thinks I should go to a place that does everything in house, as I'm getting Sposaro to build up the engine and he's outsourcing the tuning to Creatd.
Mate recommends JPC.
They built his drag VL, and his 400kw Xr6.....
So cownfushun
Don't your cousins own Rajab..?
LOL!
or at least if you cant find a workshop that covers warranty
at least you will know up front that its not covered
so if and when something goes bang you are aware of where you stand etc
ntohing worse than a nice build failing at start up, first run in or early KM stages
only for the owner to be told sorry not covered its your oil contimination or something etc etc
get as much info on what is covered and what isnt
ill be supplying the rods and pistons etc though.
if they can just cover their workmanship id be happy.
might just get creatd to do it.
trying to understand cams, springs etc.
f**k its confusing shit.
The line between workmanship and parts is incredibly blurred at the best of times.
Better yet Moh, buy a workshop manual and build the engine yourself. One of the most rewarding things I've ever done was build an engine! It's not that difficult, if you follow instructions carefully. Just like lego but with torque wrenches and tolerances lol.
what happened matt?
lol took a customer into the storage warehouse to look at some sinks, he says oh both your cars are in here, what do you drive daily?
me: the triton ute
customer: f**k bitches load fridges!
what happened matt?
Tried to do me for things that werent RWC items like a "soft" upper radiator hose. Rear pads were 2mm and legal limit is 1.5mm and I called him out on that and he got all defensive that oh well if you want to save $350 then we dont have to do it, then turned around and told me I should anyway. The owner of the company also told me to do some research to find out whats minimum spec for the rotors and get back to him.. like thats my job as a customer and all. Front tyres are Retreads (dont laugh, they came with the car) and the mechanic thought that meant they were damaged on the sidewalls, even though its just the cap glued on. Also tried to find the slightest imperfection in every bush so is trying to sting me for most of them in the rear and a couple in the front. All up about $1000 if I don't do the brakes.
(This is on a VLT also, none of this would happen on a skyline :P)
Guest
    • I recently did this to my R33 with the full set from Car Mats Direct, they can't do the vinyl anymore that's advertised on the website due to a supplier issue so I ended up with the Black Loop Pile which looks great. I went all out with rubber sound deadening sheets from Repco and also added the sound deadening foam layer option with the carpet. Makes a world of difference and got rid of all the weird smells in the 29 year old interior. It was a bit of work but I'd 100% recommend it, Car Mats Direct had awesome customer service and quick postage. Replaced my seats with some sporty ones from Autotechnia while I was at it, feels like a new car.
    • Got the motor out and torn down. I'll be dropping off the block Monday. Luckily the scoring on Cyl6 is much less pronounced then the pictures made it out to seem. It can barely be felt. If you pass your finger over it 10x you'll barely notice it. Hopefully by some chance it will only require a honing. I'm not in the mood to buy one size larger pistons or another block. Oddly enough my 6th cylinder with the scoring has extremely clean intake valves compared to my other 5 cylinders. I'm worried the scoring was caused by too much fuel or Water/Methanol washing the cylinder. I'll review some old logs to confirm.  This was also the first time I pull an engine with the transmission still attached. It went much better then expected. I was worried my CD009 wouldn't make it easy due to its sheer size but it was much easier this way.
    • From the pictures I have when doing the job the flywheel is the same diameter, I don't think they're playing weird tricks like putting weights at the outer diameter to increase flywheel inertia or anything like that. The OEM flywheel is definitely heavier, but it's not a huge difference. Quoted weight savings of the clutch is 2 kg so I can't imagine the flywheel being lighter than ~7 kg. Kind of regret not weighing it before the clutch went into the car but as far as driveability goes I have no complaints.
    • HKS trigger kit should be very easy to integrate with a Link. It's a 36-2 crank trigger. Hard part is finding the motivation to take off the timing belt and everything on the front of the engine to install it. You also need to cut out a hole in the oil pump housing so the sensor can read the trigger wheel. Changing out the cam sensor for a 24 tooth setup is probably good enough but as others have mentioned depending on what underlying assumptions are changed it becomes more of a problem. Reading the crank state off of the cam is an abstraction that works in the general case, but if you have an edge case it makes less and less sense. There is a GTX2860 gen 2 that can take a compact 5 bolt housing so it's direct bolt on but I'm not 100% sure of what's involved. Peak compressor efficiency drops off a bit on these turbos vs -5s, 77% vs 73% but you get way, way wider region of operation. The -5s have a really strange surge line in their compressor map that is all over the place. If you think the hot side on the -5s aren't open enough you can try the Tomei T550B turbos which a local tuner seems to be happy with:
    • i need a complete tail light for my R33 GTR if you have please let me know.
