Since when did it go away, As far as I'm aware it plays for like 10 months of the year which is a pretty f*kn long winter for a winter sport.
I guess if you don't like footy it can be a bit annoying being played so much lol
Yeahhhh buddy.
How's ya team looking?
Looking ok so far, apart from a few non-performing rookies
I got some spare spots in my league, wanna join brah?
No! And always try to get an assessor that is partially in your best interest. Depending on whether you are loaning, buying, selling different assessors can be used with some degree of bias. ie an Insurance assessor will do a more critical job than a bank assessor because the insurance assessor must find all potential issues that they may have to fork up later on, a real estate assessor depending on whether it's for the sale or the buying of a property will have assessors to either under or over value the property. Comprende?! :)
Comprende!
But this is for my own house for the lulz for my own curiosity.
Not buying or selling anything :P
Yeah buddy PM us ya league code and I'll join!
Which is probably why I asked Alex, who is a real estate agent :/
Not looking at selling so don't really want to waste their time
It's only fair, people ask you questions all the time about accountancy, without wanting to pay for waste another accountant's time :P
Sorry tony if it was in my area of trade I could! But we only service one suburb so itd be an uneducated guess best bet is look at what renovated ones are asking compared to un renovated
An agent will happily do it man regardless of selling or not just tell em up front I'm not selling can ya gimme a quick idea only takes 5 minutes and youll get an appraisal letter for your records!
League Code is: 186439
Got heaps of spots so any wastelanders are welcome to join
Touche'
You suck balls Alex, no soup tax advice for you :P
Jokes brah, all good was just curious :thumbsup:
LOL!
Blame Grant he said they were good and lenient :P
Why do you have to blame me?
Cause of what Borci88 said :laugh:
Guest
    • When's the rear mounted turbo kit coming? Needs dose and V8 chop idle lol.
    • I was very unimpressed with how the car came up from the A pillar forward, before I hit things (twice). It all has to go. It had to go, but now it has to go... more. So we finally found the very first Shennanigans with the entirely perfectly setup engine that had no problems being pulled apart to improve on 'was perfectly fine'. Cam bearings looked a bit... stock. Which isn't entirely bad given they were stock and this is a ~20 year old engine. So new cam bearings are on the way because it's somewhat difficult to get to this stage to do it later, and it will trash the block. It was quite unusual that it wasn't done when the perfectly new-looking VCM cam was originally installed by [unknown] What IS unusual is the cam that was installed there was advanced SIX degrees. As to why there is no way to know.. however it could have been @Dose Pipe Sutututu's mate who wanted a larger cam sound but also wanted it to come on earlier to be more usable. This is my dyno sheet with the previous setup - This cam is not supposed to peak until 7000+ RPM, according to VCM. This is what lead me down the whole 'my heads/intake setup is running out of puff and can't support the cam' line of thinking to begin with. Anyway too late now - New cam is in! It could be rather funny if this smaller cam acts like a larger cam because it isn't advanced six degrees. In the spirit of everything is working amazingly - the COMP cam required no dialling in whatsoever. It was about 0.5 degrees advanced, which seems pretty bang on. Any adjustment either way would be further out. In the spirit of everything was previously working amazingly - The timing gear that was taken out turned out to be was an N-Motion double timing chain kit, with adjustable cam gear (which is how it was 6 degrees advanced) and all looks entirely perfectly new. It also had a Torrington bearing, which was one of the reasons I ended up getting the Cloyes kit which they used in the C5R 24 hour racecar - Because I couldn't confirm what was in the engine when talking to Tony Mamo. I did believe however it was a Double chain kit of some kind... but found no supporting documentation or evidence for it.
    • I recently did this to my R33 with the full set from Car Mats Direct, they can't do the vinyl anymore that's advertised on the website due to a supplier issue so I ended up with the Black Loop Pile which looks great. I went all out with rubber sound deadening sheets from Repco and also added the sound deadening foam layer option with the carpet. Makes a world of difference and got rid of all the weird smells in the 29 year old interior. It was a bit of work but I'd 100% recommend it, Car Mats Direct had awesome customer service and quick postage. Replaced my seats with some sporty ones from Autotechnia while I was at it, feels like a new car.
    • Got the motor out and torn down. I'll be dropping off the block Monday. Luckily the scoring on Cyl6 is much less pronounced then the pictures made it out to seem. It can barely be felt. If you pass your finger over it 10x you'll barely notice it. Hopefully by some chance it will only require a honing. I'm not in the mood to buy one size larger pistons or another block. Oddly enough my 6th cylinder with the scoring has extremely clean intake valves compared to my other 5 cylinders. I'm worried the scoring was caused by too much fuel or Water/Methanol washing the cylinder. I'll review some old logs to confirm.  This was also the first time I pull an engine with the transmission still attached. It went much better then expected. I was worried my CD009 wouldn't make it easy due to its sheer size but it was much easier this way.
    • From the pictures I have when doing the job the flywheel is the same diameter, I don't think they're playing weird tricks like putting weights at the outer diameter to increase flywheel inertia or anything like that. The OEM flywheel is definitely heavier, but it's not a huge difference. Quoted weight savings of the clutch is 2 kg so I can't imagine the flywheel being lighter than ~7 kg. Kind of regret not weighing it before the clutch went into the car but as far as driveability goes I have no complaints.
