Counterfeit stuff cheaper in HK or bangkok
add in if you want to leave airport in China there is a visa so there more money to spend.
accom in Dubai and Abu Dhabi can be very expensive for safe good accom, (and you will have all your stuff with you)
that said like all things with airlines you get what you pay for.
and remember you will be stuck in your seat for upwards of 24 hours.
so things like:
every seat in economy on Cathay has it's own power socket
Qantas 380 has a (non alcoholic) bar where you can get drinks and snacks any time on the flight
so is the important thing
cost
stopover
comfort on flight
Martin, thanks for the reply, you raised some valid points.
Have you (or anyone) been in Qatar airlines? Prices are reasonable also the flight time including stop overs.
The power socket on Cathay Pacfic sounds so handy for me... Need to find out the cost for this flight.
No idea, I went on there to post in some thread ,... couldnt do it checked some shit apparently I've been banned from posting ... hahahaha I usually get in there and make threads about drifting lavo factorys n stuff for lulz then they shut down the threads.
Welcome to 2004 - Pretty sure I had a suspension a long time ago :D
kittens are so awesome.
Will hit it often when the mrs' parents holiday house is built there
See how subtle I was there?
SAU brings the LOLS!
not flown them myself.
the Cathay point is great just make sure you carry a UK power adapter as that what they use.
worth checking as well is:
http://www.seatguru.com/
as it shows the size of seats and the space between them for different airlines.
also where power sockets are and seat layout.
eg qatar and Cathay have 32 inches of room between seats Qantas has 31 inch.
hmm starting to sound like a travel agent here!
Martin, many thanks once again!
Qatar - Boeing 777 only have power point in Business Class, however on Airbus A340-600 does have on all seats.
Hmm... Decisions decisions...
Edited by Count Grantleyish
Guest
    • First up, I wouldn't use PID straight up for boost control. There's also other control techniques that can be implemented. And as I said, and you keep missing the point. It's not the ONE thing, it's the wrapping it up together with everything else in the one system that starts to unravel the problem. It's why there are people who can work in a certain field as a generalist, IE a IT person, and then there are specialists. IE, an SQL database specialist. Sure the IT person can build and run a database, and it'll work, however theyll likely never be as good as a specialist.   So, as said, it's not as simple as you're thinking. And yes, there's a limit to the number of everything's in MCUs, and they run out far to freaking fast when you're designing a complex system, which means you have to make compromises. Add to that, you'll have a limited team working on it, so fixing / tweaking some features means some features are a higher priority than others. Add to that, someone might fix a problem around a certain unrelated feature, and that change due to other complexities in the system design, can now cause a new, unforseen bug in something else.   The whole thing is, as said, sometimes split systems can work as good, and if not better. Plus when there's no need to spend $4k on an all in one solution, to meet the needs of a $200 system, maybe don't just spout off things others have said / you've read. There's a lot of misinformation on the internet, including in translated service manuals, and data sheets. Going and doing, so that you know, is better than stating something you read. Stating something that has been read, is about as useful as an engineering graduate, as all they know is what they've read. And trust me, nearly every engineering graduate is useless in the real world. And add to that, if you don't know this stuff, and just have an opinion, maybe accept what people with experience are telling you as information, and don't keep reciting the exact same thing over and over in response.
