Took the VLT to get a roadworthy elsewhere, smaller list and should take a lot less time. I should sell RWC-less from now on, what a head f**k.
The RWC on my Pulsar cost $1,100, only sold the car for $6,000. Bit of a kick in the teeth. Now had they fixed everything it would have been so much more. Never realised how many stupid things count as roadworthy items these days.
Edited by llama_au
not made it out of the terminal at Singapore, want do some day tho.
the nuggets in Germany were that whole fake meat you see on the you tube clips, you know the shite that comes out looking like pink icecream.
and the burger I had somewhere out of vegas on route 66 was just dripping with fat.
Grant yeah quite a few countries sell beer at macca's and co.
Australia is very tight with where you can buy booze.
most other palces are very lax about beer sales, (and stiffer on spirits and wines)
hell thought most of Asia I can buy beer at 7/11
Germany has it for sale from the petrol station
I even found a beer vending maching in South Africa, hows that for responsible serving of alcohol
Ordering a beer with your KFC meal deal combo in Tokyo was awesome :)
Guest
    • Oh man what a deal.... Funny enough (well not really) I sold a car to some old dude (buying for his Daughter) on a Saturday, He asked if she could take the car now and pay me the money on Monday as the bank wasn't open. Needless to say I told them to come back with the cash or get f**ked! Luckily the money seemed to magically appear in his pocket a few minutes later, so it all ended well (for me).
    • Gucci bags tend to hold their value well, so someone’s definitely going to get a nice find here.
    • @Ozdavroz Not going to get a better deal than that. Cash up front and ongoing payments. 🤑
    • I wouldn't even move it like gTSBoy is saying. I'd seriously do what Duncan is saying. Unplug the injectors, and unplug the fuel pump.  Pull the spark plugs out. Have a look in quickly with a bore scope if you want. At most, you can't spray a bit of oil into the bores so there is lubricant in there while you crank it. (Don't fill it, as it's only going to enter the exhaust, or spit at you out the spark plugs holes. Before cranking the engine on the starter, after a 5 year sit I'd probably prime the oil system manually. Easiest way to do so is to look at buying an oil filter relocation block, fit it to the engine. The pressure line going into the engine on this block you can then shove into some sort of oil pump, or put it into a bottle, with that hose going to the bottom. Fill bottle up with oil. Now seal the bottle and add a compressed air line to the top of the bottle. Feed compressed air in, about 20psi will be PLENTY. This will pump oil through the motor. Be aware, it also means it will drain back to the sump, so make sure you don't end up over filling the motor Now bolt the old oil setup back on (or fully install the remote filter system).   This way you've at least pushed fresh oil everywhere, then you're letting the motor crank to then do its own oiling. Then I'd tap the key to make sure it can start to crank, if the motor free bumps, then I'd just hit the key and let it crank. After letting it crank and seeing you can get real engine oil pressure, put new spark plugs in, reconnect the fuel system electrics, and send it.   Additionally, you can look to remove the fuel feed line to the rail, and divert it to a tank so you can get the bottom of the tank shit out, and just incase there's some crud sitting anywhere that gets passed the fuel filter (or is already ahead of it).   If fuel injection at the injectors ends up appearing to be a problem, you can dump the injectors into an ultrasonic cleaner for a quick flush clean out. Note this isn't as good as new injectors, or getting them pro cleaned and flowed
    • All I can say is, that's still bloody awesome! No plans on caging it I'm guessing?
