Xbox has the same problem, CPU and GPU heatsinks don't stay clamped down enough and vibrations + heat make the components seperate from the motherboard over time. You can also fix an Xbox by putting it in the oven, but it doesn't always work and you can easily damage the other components on the MB. It fixed my mate's Xbox, though afterwards, his Xbox would occasionally freeze with intense graphic gameplay. Ash's mate reckons $85 but not guaranteed to fix...they use a rework station though which is much safer than ye olde oven lol.
lies, ghetto fixes are always the best
just got back from my first proper ride. still alive!
did ~60ks
hit ~130 on the freeway, was freezing! felt like my chest was being punched in...
wrists raped
talked so much shit to myself i ate most the insides of my mouth/cheeks, gets lonely...
at 100km/h bike sits at just under 9k
/bikes
Ride on Sunday may be a go ahead now...bike is getting serviced this morning, hopefully pick up around midday :)
And yeah you spend a lot of time talking to your helmet, mostly about how bad drivers are.
did ~60ks
wrists raped
/bikes
It does take a fair bit of energy out of you, even though u guys are buff kents as well, I'm the smallest with heaviest bike :(
Make a thread? :) <3
Was on melton hwy doing the speed limit this a$shole gets up my arse starts flashing his lights, got out of his way/showed him my finger. 5 seconds later I pull up next to him at the lights, gave him a clap congratulating him on getting so far ahead of me, didnt even have the balls to look my way
On my way home exiting the freeway I stalled the bike taking off uphill at the lights, mint chick stops behind me to make sure I dont get rear ended by someone speeding up the ramp eventhough I waved her to go round, waited there till I got the bike going again.
Moral of the story - there's bad/good drivers just hope I dont come across the bads often
Guest
    • Got the motor out and torn down. I'll be dropping off the block Monday. Luckily the scoring on Cyl6 is much less pronounced then the pictures made it out to seem. It can barely be felt. If you pass your finger over it 10x you'll barely notice it. Hopefully by some chance it will only require a honing. I'm not in the mood to buy one size larger pistons or another block. Oddly enough my 6th cylinder with the scoring has extremely clean intake valves compared to my other 5 cylinders. I'm worried the scoring was caused by too much fuel or Water/Methanol washing the cylinder. I'll review some old logs to confirm.  This was also the first time I pull an engine with the transmission still attached. It went much better then expected. I was worried my CD009 wouldn't make it easy due to its sheer size but it was much easier this way.
    • From the pictures I have when doing the job the flywheel is the same diameter, I don't think they're playing weird tricks like putting weights at the outer diameter to increase flywheel inertia or anything like that. The OEM flywheel is definitely heavier, but it's not a huge difference. Quoted weight savings of the clutch is 2 kg so I can't imagine the flywheel being lighter than ~7 kg. Kind of regret not weighing it before the clutch went into the car but as far as driveability goes I have no complaints.
    • HKS trigger kit should be very easy to integrate with a Link. It's a 36-2 crank trigger. Hard part is finding the motivation to take off the timing belt and everything on the front of the engine to install it. You also need to cut out a hole in the oil pump housing so the sensor can read the trigger wheel. Changing out the cam sensor for a 24 tooth setup is probably good enough but as others have mentioned depending on what underlying assumptions are changed it becomes more of a problem. Reading the crank state off of the cam is an abstraction that works in the general case, but if you have an edge case it makes less and less sense. There is a GTX2860 gen 2 that can take a compact 5 bolt housing so it's direct bolt on but I'm not 100% sure of what's involved. Peak compressor efficiency drops off a bit on these turbos vs -5s, 77% vs 73% but you get way, way wider region of operation. The -5s have a really strange surge line in their compressor map that is all over the place. If you think the hot side on the -5s aren't open enough you can try the Tomei T550B turbos which a local tuner seems to be happy with:
    • i need a complete tail light for my R33 GTR if you have please let me know.
    • I need a great maintenance workshop around Idaho, if you know one please let me know..
