ah about heat treating.
aluminium goes though a phase change only at about 500+degrees, so you'll be alright...
by phase change i mean change in crystal structure. i could be wrong though, need to flip through some notes.
forget what i just said. the aging is done at between 100-200 degrees, so yup. powder coating is bad yo.. unless, it only heats the surface and the wheel does not really reach 200degrees on the inside, you only bake the surface anyway, right?
yeah but after you come to a stop, so I do a cool down lap but still you can light a match off the rotor after you aprk it, 20-30 min later has to have warmed up a rim quite a bit???
I'm prob wrong, should bring a thermal probe to one and have a play
I wouldn't be game to risk it :P
Where to buy spacers from guys?
Instead of being:
20x10 +42
20x8.5 +35
I got:
20x10 +38 (don't really care about that - more baws)
20x8.5 +42 (7mm more in on the front than I was meant to be getting..)
So now thinking a 5mm 8-10mm spacer? where to buy? ebay have a fair few is matching the center bore of the hub important?
lol not sure if trolling jonoe? :P
Alex, cant they're already here.. got them 2nd hand and cbf chasing shit up - just the fron'ts I have a problem with they wont be flush at all so thinking of spacer.. if i really like rims maybe buy 2x propper sized ones and rip skids on the others or something lol..
If specs aren't as advertised send em back ?
eh got them at a decent price + cbf sending shiz back I think it was a honest mistake by him so might try some small spacers to push it out
ford have factory spacers anyway as dust guards on the rear lol
Guest
    • First up, I wouldn't use PID straight up for boost control. There's also other control techniques that can be implemented. And as I said, and you keep missing the point. It's not the ONE thing, it's the wrapping it up together with everything else in the one system that starts to unravel the problem. It's why there are people who can work in a certain field as a generalist, IE a IT person, and then there are specialists. IE, an SQL database specialist. Sure the IT person can build and run a database, and it'll work, however theyll likely never be as good as a specialist.   So, as said, it's not as simple as you're thinking. And yes, there's a limit to the number of everything's in MCUs, and they run out far to freaking fast when you're designing a complex system, which means you have to make compromises. Add to that, you'll have a limited team working on it, so fixing / tweaking some features means some features are a higher priority than others. Add to that, someone might fix a problem around a certain unrelated feature, and that change due to other complexities in the system design, can now cause a new, unforseen bug in something else.   The whole thing is, as said, sometimes split systems can work as good, and if not better. Plus when there's no need to spend $4k on an all in one solution, to meet the needs of a $200 system, maybe don't just spout off things others have said / you've read. There's a lot of misinformation on the internet, including in translated service manuals, and data sheets. Going and doing, so that you know, is better than stating something you read. Stating something that has been read, is about as useful as an engineering graduate, as all they know is what they've read. And trust me, nearly every engineering graduate is useless in the real world. And add to that, if you don't know this stuff, and just have an opinion, maybe accept what people with experience are telling you as information, and don't keep reciting the exact same thing over and over in response.
