Pedders 'extreme xa coilovers'
it was either that or teins, but teins are $2500 for fords because shock is separate to spring on the rear. (pedders 1750)
Alex find me some ballin' rims!
19or20 x 9 +20ish
19or20 x10 +38ish
they're the flush / slightly agressive sizes for mine
you could go 9.5 rear with a lower offset as well
Got a small cyst that's grown a little over the years, thought it time to get checked out. Sebaceous baby.
Oh good. I had one of those on my wrist for a little while, hurt when I bumped it. Then it was gone one day all by itself.
are toyota 114.3 though?
yeah don't mind ordering newies just need to find some good ones at a half decent price
some toyota are. the poopra, the snorer are 5 x 114.3
but my mr-s is 4 x 100. weird hey? why? the past mr2s were 5 x 114.3 too.
~7km of bliss, I almost know it like the back of my hand. Poor residents have to listen to my R1 on song during the straights ^_^
I really should get down to Phillip Island...
I watched friends go off there back in the day. Not a particularly forgiving road. Nice drive though. I love Ridge Road (the road between Kalorama and Olinda that Skyhigh sits on.)
I wouldn't want poop on my rims though, that and newb gutterash so might be going newies next set probably be after tune :D
Guest
    • Got the motor out and torn down. I'll be dropping off the block Monday. Luckily the scoring on Cyl6 is much less pronounced then the pictures made it out to seem. It can barely be felt. If you pass your finger over it 10x you'll barely notice it. Hopefully by some chance it will only require a honing. I'm not in the mood to buy one size larger pistons or another block. Oddly enough my 6th cylinder with the scoring has extremely clean intake valves compared to my other 5 cylinders. I'm worried the scoring was caused by too much fuel or Water/Methanol washing the cylinder. I'll review some old logs to confirm.  This was also the first time I pull an engine with the transmission still attached. It went much better then expected. I was worried my CD009 wouldn't make it easy due to its sheer size but it was much easier this way.
    • From the pictures I have when doing the job the flywheel is the same diameter, I don't think they're playing weird tricks like putting weights at the outer diameter to increase flywheel inertia or anything like that. The OEM flywheel is definitely heavier, but it's not a huge difference. Quoted weight savings of the clutch is 2 kg so I can't imagine the flywheel being lighter than ~7 kg. Kind of regret not weighing it before the clutch went into the car but as far as driveability goes I have no complaints.
    • HKS trigger kit should be very easy to integrate with a Link. It's a 36-2 crank trigger. Hard part is finding the motivation to take off the timing belt and everything on the front of the engine to install it. You also need to cut out a hole in the oil pump housing so the sensor can read the trigger wheel. Changing out the cam sensor for a 24 tooth setup is probably good enough but as others have mentioned depending on what underlying assumptions are changed it becomes more of a problem. Reading the crank state off of the cam is an abstraction that works in the general case, but if you have an edge case it makes less and less sense. There is a GTX2860 gen 2 that can take a compact 5 bolt housing so it's direct bolt on but I'm not 100% sure of what's involved. Peak compressor efficiency drops off a bit on these turbos vs -5s, 77% vs 73% but you get way, way wider region of operation. The -5s have a really strange surge line in their compressor map that is all over the place. If you think the hot side on the -5s aren't open enough you can try the Tomei T550B turbos which a local tuner seems to be happy with:
    • i need a complete tail light for my R33 GTR if you have please let me know.
    • I need a great maintenance workshop around Idaho, if you know one please let me know..
