Also, whats up with the forum time? even with +10 timezone selected I'm posting from the future :O
Edit: ah it's the auto detect daylight savings.. you have to untick it in settings if anyone else is getting the same problem
Roll up between VE GTS and N/A Subaru Liberty with a loud exhaust. Subaru thrashes the shit out of his engine to get nowhere fast, we both take off calmly and casually. Sucker.
soo tired this morning fml.
anyone get on diablo 3 last night?
Holding out for Max Payne 3.
Been hearing alot about Diablo 3 must be an epic game. Never have played any Diablo series
Gave up gaming a long time ago, becuase I'm the sort of person if I get addicted to a game I'd play it till 3a.m non stop :/
I am guessing it was either the 2nd or 3rd Gen Subaru Liberty with a muffler can from Auto Barn..?
lol, love cruising <2k rpm with the auto and getting up to 80 much quicker than other dudes so much low down torque and power!
motorbike I usually take off in 2nd as well.. so I dont use clutch to upshift but from 1-2 i normally would because I dont like going past neutral clutchless - sounds cooler also :D
Guest
    • Of course you can. That was a waste. Straight down one oil drain gallery and out the sump hole. Could at least have run the engine a little (obviously with at least minimum oil level on the stick).
    • Oh really? Maybe I'm being silly. I'll get some more shots. I had it higher but found that it went too high after a drive, I never knew this but exhausts can move around a bit when hot (makes sense, just never knew) and when it was higher it would make nice cooking plastic smells. That said, I could put some heat tape on a'la 90's R33 exhausts     Ha, I've spent a lot of my life in castle hill waiting for cars to be done. I think I'd prefer something closer but thanks D.
    • @Duncan Yes, changed filter every time. I don't have the service manual for the car yet (Car was imported and they removed everything when importing). I've been using the oil change threads in the forum as reference.   @Milkmun The second oil change was after ~4 months after the first months and I wasn't sure about reusing engine oil that was opened. The third oil change happened within 3 weeks of the second oil change and I used the previous leftover oil to just "clean up" the system. (Poured it through while the sump plug was open")
    • I left the ceramic coating off this bit, hopefully it just comes off after a few drives.   The gap between the spokes is too tight for anything on a stick, its only marginally bigger than my finger. I have to use a brush to get in there and its a big reason why I thought I'd try the coating.   Absolutely will do. I have EBC Blue Stuff pads to put on the front which will make them a bit dirtier. I'm hoping a pressure wash will just get most off. The shine is different to most, its very thin but seems very well 'attached' so hopefully it lasts.
