Was thinking that when Basti fixed his post.
didnt change anything in my post. just a spelling error
So for those that couldn't work it out... I'm pregnant (well merowyn is) :D
damn was hoping for some arnold schwarzenegger style, Junior-esque shenanigans.
the TE37 reps.
nah wasnt happy with the 8.5 inch meisters lol.
im waiting on 9.5 + 12 and 10.5 +22 in 18".
The GTX3071R will be going on soon and I would like some sort of traction
f**k yeah
When I said 'his' post, meaning Hamish's post.
i like this because of the radness
Hell yeah man!
Congratulations :D
Place your order now :D
the TE37 reps.
Intradasting... How does the GTX3071R go on the sr20's?
You'd expect 280-300rwkw on the Rb's? So how would they go on the sr20's? Also when would you expect to hit full boost ~18psi? it would be about 3.5krpm on the rb25 i think?
I want to definitely hit over 300kw with e85. Hopefully I'll be at 20psi by about 3800-4k with the stage 2 cams. Bit laggy but I'm not fussed Using a .82 rear so we'll see how it goes. Can always go a smaller housing
the TE37 reps.
Kranzes would have looked dope!
Guest
    • For a daily just run Akebono ceramic pads. That's what they're optimized for. Obviously don't try to run it on track or anything like that.
    • Hey all, I'm sorry if this has been discussed before.  I have a 2008 Japanese import V36 coupe with nav but without Bose. I bought one of those AliExpress android screens, which for the most part works really well.  The only thing that doesn't work is the air con controls (well sort of) and the factory reverse camera.  The AC can be controlled fine but it doesn't report the change in temp and mode to the screen, and the volume knob/other audio controls from the panel don't register on the learning app.  I am pretty certain that the problem is the difference in the head unit between base model (Nav but no Bose) 2007-2009 coupes and anything after 2009.  Mine is the one with the blue connector all the way to the right as seen in this forum post:  The reason I think this is there is one wire left over that doesn't fit anywhere on this head unit, or in the factory screen which also uses different connectors to more recent versions.  I've seen the upgrade from OWC, and have sent the guy a message on eBay but no response yet.  I also don't particularly need the whole kit, just *maybe* an adapter for this one cable.  Did anyone else here have the same problem, or have any insight about what I can do to get this working?  I have been in contact with the seller but all they seem to be able to do is ask for more pictures and videos. Minor edit to add:  I have been researching and found a screen on Aliexpress that actually specifies my head unit in the listing, so these things do exist.  I will contact the seller to see if the wiring adapters are interchangeable with other screens.   Thanks in advance!
    • Can't go wrong with tourings/estates/wagons.
    • Oh poop ! I missed the "deposit" in your post !
    • I laughed so hard a snot bubble popped out my nose !  And seriously ! You can still buy a decent house in Western Sydney for 2 mill ? ?
