Anyone ever seen that plastidip shit in person?
Looks to good to be true, but if it peels off the windows that easily what's to stop it doing the same on your panels?
I guess people wouldn't know the difference if its done right. And it's only that easy to peel off if it's half cured I think. Meant to be a bit harder or almost like vinyl when it's on for a few hours
Would do the EA for a laugh but I'd say the paint needs to be good to begin with, or prepped, and I won't do that
Yeh I think it needs to be pretty well prepped like clay bard or something. But I would do a panel that I have laying around at home first before I attacked my car
Got 2 mates that would be interested in doing in.
What sort of costs would you be looking at to do the plasti dip?
Well after checking my bank history turns out I never actually confirmed payment, so I'll probably buy it in a couple of weeks. I'm happy to do other peoples cars but would want to do mine first to see whats involved and if I actually do a good job for starters
Lol I posted a picture and they all started crying because they are varrstoens. Took them a while to figure out that it isn't their car. Lol
Yeah cuz Varrstoens aren't JDM AS FUCK!
Actually an NS member posted a topic about ROTA Wheels.
Was an interesting read.
Don't be mean they will cry
Lol yeh man I'm sick of the debates though.
LOL!
Yeah, once you're on NS for a bit you can actually filter out the shit.
I like NS.com, there are some good members on there who know their stuff and you can find some interesting threads.
I think I will now
The thread topic is usually a straight up give away if the topic is going to be good or not.
Then you read the first few post, if it's all shit talk = Shit thread.
Constructive discussion = Good thread.
Nisskid has the know-how.
In one thread, he was explaining to us about the types of wheel qualities and builds through out different brands.
I just asked them where I can get volk rays stickers from
LOL! For the trololols!
I bought a sticker set from On The Run Motorsport.
Guest
    • Yep, pretty much what you said is a good summary. The aftermarket thing just attached to the rim, then has two lines out to valve stems, one to inner wheel, one to outer wheel. Some of the systems even start to air up as you head towards highway speed. IE, you're in the logging tracks, then as speeds increase it knows you're on tarmac and airs up so the driver doesn't even have to remember. I bet the ones that need driver intervention to air up end up seeing a lot more tyre wear from "forest pressures" in use on the highway!
    • Yes, but you need to do these type certifications for tuning parts. That is the absurd part here. Meaning tuning parts are very costly (generally speaking) as well as the technical test documentation for say a turbo swap with more power. It just makes modifying everything crazy expensive and complicated. That bracket has been lost in translation many years ago I assume, it was not there.
    • Hahaha, yeah.... not what you'd call a tamper-proof design.... but yes, with the truck setup, the lines are always connected, but typically they sit just inside the plane of the rear metal mudguards, so if you clear the guards you clear the lines as well. Not rogue 4WD tracks with tree branches and bushes everywhere, ready to hook-up an air hose. You can do it externally like a mod, but dedicated setups air-pressurize the undriven hubs, and on driven axles you can do the same thing, or pressurize the axles (lots of designs out there for this idea)... https://www.trtaustralia.com.au/traction-air-cti-system/  for example.... ..the trouble I've got here... wrt the bimmer ad... is the last bit...they don't want to show it spinning, do they.... give all the illusion that things are moving...but no...and what the hell tyre profile is that?...25??? ...far kernel, rims would be dead inside 10klms on most roads around here.... 😃
    • You're just describing how type certification works. Personally I would be shocked to discover that catalytic converter is not in the stock mounting position. Is there a bracket on the transfer case holding the catalytic converter and front pipe together? If so, it should be in stock position.
    • You talking about the ones in the photo above? I guess that could make sense. Fixed (but flexible) line from the point up above down to the hubcap thingo, with a rotating air seal thingo. Then fixed (but also still likely flexible) line from the "other side" of the transfer in the hub cap thingo up to the valve stem on the rim. A horrible cludge, but something that could be done. I'd bet on the Unimog version being fed through from the back, as part of the axle assembly, without the need for the vulnerable lines out to the sides. It's amazing what you can do when you have an idea that is not quite impossible. Nearly impossible, but not quite.
