it's easy you just click up :happy:
mechanic just picked up my bike, he recognized it soon as he saw it says he's worked on it before
I do, it's the only way to keep the speed down ironically...
Haha was it a "oh I remember this bike" or an "ohhhhhh, that thing"?
linklinklink
F&F quote is deleted, i ruined the mod's argument and he removed the warning lol
Nah man, but if I keep riding it I reckon I will. Can't have fun on it without breaking a lot of laws :/
Remember the first few days of owning a turbo car, how easy it was to get up to speed limits and find yourself surpassing them...multiply it by 11ty :/
i think before something happens to you ie. injury, you should probably get on a track or watch some video's of bikers crashing. seriously
Have watched videos of guys heads split in two (literally) in motorcycle crashes, it doesn't stop you from twisting the throttle when you're chasing an adrenaline kick. I know the risk I'm taking, that's what makes it exciting I guess. The track is a lot safer and my goal is to eventually get my fixes there...
lol nah he spoke very well of it, which was a relief...
i have trouble getting the speed up on the bike lol it just feels like i'm going way faster than the speedo is reading but i guess it's just coz i'm new to it...
i cant imagine it, i think what you just explained is the reason i refuse to get my learners.
in all seriousness though i dont know what these dream boats are on. i thought it looked alright.
First post I read when I clicked on the NS link is "set of professors with new federals", I closed off the window.
really miss my 33
i think i just miss a fast manual turbo
the BA wagon is tops but do miss quick fast car with loud spooling noises
evo 8 6 spd or BCNR33 ?
e8 is way more attractive.... but 33R is old trusty
Guest
    • They see me rollin' they hatin'....... Took me most of the day to make the necessary mods to the mounts to make them fit the car.  Fortunately I was able to just use the mounts that came with the rotisserie. The rear ones are really secure, the front I feel i might reinforce a bit more as it doesn't seem like enough attachment to the vehicle. I'm sure it's fine but better to be safe than (extremely...) sorry.  I drilled and tapped thread into additional M12 holes to each car mount where it attaches to the rotisserie as an extra fail-safe. Without them the side to side movement is just restricted by the allen head pinch bolts, nothing actually goes though the beam. Does now! I still need to adjust the rotisserie to get the car centred in terms of centre of gravity. If it's too high or too low relative to the rotational centre line of the car, it will be like a turtle and roll onto its back or as it currently sits, I dont think I'd be able to rotate it as it sits as it needs to lift the whole car up as it rotates. Ain't happening... I'm going to be nervous as hell the first time I go to spin it on its side...
    • Oh yes done this when the window started flopping around.  Turns out the guides that run along the rail chanel had crumbed way. Took off the door card and pulled out the window mech, then the window, which you have to pull out through the top. As said unbolt the guide rail and don't spend 30 minutes getting frustrated trying to find a way to slide it out upwards cause that don't frigging work. Drop it down and out through the door hole. All I did to repair it was slice some 10mm clear plastic tube, vertically, then screw it to the guide rail both sides. This tubing rolls inward on both sides and leaves a gap wide enough to hold the window. To finish all I did was lube the plastic tube with olive oil and Bob's your uncle . . . well if he has the operation he can be your Aunt ! !  10 bucks in plastic tube and another 5 minute job done again . . . . YEH BULLSH#T ! My love for Skylines knows no bounds !
    • So was there a solution to this problem? I’m having this issue now.
    • not expensive, just irreplaceable if you don't go sub 60 at wakie in that thing people will start talking
    • I haven't replaced that, but I have had the doors apart on the r32 a couple of times The door skin will be held on by a combination of clips and bolts, just take it slowly and make sure all the sneaky hidden bolts are out Once the skin is off you should be able to pop that piece off pretty easily, looks like there are only 2 bolts holding it on
