Alex that's about right, my other mates with SS's xr8s etc all seem to be roughly the same figures as mine, the commodore maybe uses a bit more
But teh power and sound can't be beaten :P I fill up and still get 4-500ks depending on how / where I drive
Freeway about 8.5l per 100 I almost made it back from Canberra on the same tank
If only the sirocco was awd that would be awesome. Although the golf R is no compromise either. Both good looking cars.
On another note pulled up to a Bmw with a V12 badge. Turned out to be a 760li. That will be $414000 thanks O_o
Lol, I can't wait till I have a little mohsen running around.
Id buy the little Kent one of those electric cars they drive around and slam it
You need to have a real girlfriend first, and they also need to have hit puberty
Yeh just gets ya worried when reviews say it uses a massive amount of fuel lol 14/15 can live with more than that no thanks.. Lol plus I never hit freeway all suburb driving lol
Seems mk2 is best to get if you can the guy @ bay ford wasn't too helpful left knowing the same as when I got there :/
Edited by alr33x
Post pic of golf r wanna see what they look like.
Also hate Internet when u actually want quality info on something good fkn luck finding it... Most fpv reviews say its drinks fuel list no tomorrow but dont actually quantify how much.. Check thread on form forums average seems about 14-15/100km which I rkn is decent for what it is doubt any v8 would come in much lower? Any v8 owners around lol?
last time I drove mine gets around...25L/100km freeway use...less in city..
but prob not best example
66 mustang with a 289, hot cam, extractors, 600 holly with a 3 speed c4 auto.
that drive train is now gone, putting in a 5L efi windsor with a 4 speed auto hoping to get around 15ish /100 with the light weight car.
Guest
    • From the pictures I have when doing the job the flywheel is the same diameter, I don't think they're playing weird tricks like putting weights at the outer diameter to increase flywheel inertia or anything like that. The OEM flywheel is definitely heavier, but it's not a huge difference. Quoted weight savings of the clutch is 2 kg so I can't imagine the flywheel being lighter than ~7 kg. Kind of regret not weighing it before the clutch went into the car but as far as driveability goes I have no complaints.
    • HKS trigger kit should be very easy to integrate with a Link. It's a 36-2 crank trigger. Hard part is finding the motivation to take off the timing belt and everything on the front of the engine to install it. You also need to cut out a hole in the oil pump housing so the sensor can read the trigger wheel. Changing out the cam sensor for a 24 tooth setup is probably good enough but as others have mentioned depending on what underlying assumptions are changed it becomes more of a problem. Reading the crank state off of the cam is an abstraction that works in the general case, but if you have an edge case it makes less and less sense. There is a GTX2860 gen 2 that can take a compact 5 bolt housing so it's direct bolt on but I'm not 100% sure of what's involved. Peak compressor efficiency drops off a bit on these turbos vs -5s, 77% vs 73% but you get way, way wider region of operation. The -5s have a really strange surge line in their compressor map that is all over the place. If you think the hot side on the -5s aren't open enough you can try the Tomei T550B turbos which a local tuner seems to be happy with:
    • i need a complete tail light for my R33 GTR if you have please let me know.
    • I need a great maintenance workshop around Idaho, if you know one please let me know..
    • Hello friends, i have a good friend in Canada that looking for a good condition 1993 GTR around him please if one or know someone around you that is willing to let it go please let me know so that i can inform him.....Thanks
