If i want to fit a new bootlid onto the car (which will be sprayed) should i look for a poor condition black one? ie. if I supply a red one and ask the painter to spray black he would then have to prep/spray the underside?
Very hard to find a black bootlid, I do have a red one but not sure if worth painting. No doubt covering the red paint on the underside would be a pain...
Any thoughts?
I'm not sure if ham is being serious or not. kinda hard to tell in text, but thanks anyways :turned:
Whole car is legal height, cat is just on 100mm. Fronts are poking out a little bit, i'll ask the dudes to camber it in a tiny bit when getting the alignment done. Only thing police can really defect me for is tint. (and being too stiff?)
I'm quite happy with the result, glad I didn't go +0 (current +20)
dead serious man... it's totally practical (well what i would call practical) looks tuff and wont attract cops unless they are SUPER bored.
little more poke on the rears could be nice but i'll wait for a front/rear shot to judge
Will grab a front and rear tomorrow. Looks a lot better irl as every other car does.
Glad people think it looks good. Wasn't really sure with the gun metal centres, as I haven't seen it before on a silver civic.
Me = Happy
And I made it up alvins driveway. that's a plus.
scirocco R is same price (thereabouts) and FWD. while it looks baller from the front and side the ass is epic fail.
golf R is 4wd - similar system to the GTR but it is front wheel biased. so when you are putting around the city or a hwy it's fwd to save fuel but when you pin it, it can throw up to 100% to the rears.
also i wont be buying new.
should get you to come past where I had my car tuned, get some rides in golf r's, modded gti's etc and see how they go
a lot of the guys tend to head towards the gti's because they are more nimble being lighter and get cools pops/bangs over the r's for some reason
Me = Happy
reckon ill make it up?
Interesting you say that Nick, cause there was a magazine shoot out a while ago, where they got tuning workshops to modify their choice of car (under a certain cost, like 60k) and the same drivers to test them all around a track. The GTIs kicked ass once modified and were actually quicker around that track than the modified R32, from memory.
Probably, try it! You got even less overhang than me. Only thing i'd worry about is your exhaust.
haha i have no rear muffler now anyway, completely straight through :P
Yeah I was surprised to hear it, but it does make sense
I'd say the R's would be really useful on a full hills run to make use of the 4wd
the older mk5's are still the v6 na so they get blitzed by the gti's unless you drop the twin turbo kits on them which are like $10k :S
Guest
    • Got the motor out and torn down. I'll be dropping off the block Monday. Luckily the scoring on Cyl6 is much less pronounced then the pictures made it out to seem. It can barely be felt. If you pass your finger over it 10x you'll barely notice it. Hopefully by some chance it will only require a honing. I'm not in the mood to buy one size larger pistons or another block. Oddly enough my 6th cylinder with the scoring has extremely clean intake valves compared to my other 5 cylinders. I'm worried the scoring was caused by too much fuel or Water/Methanol washing the cylinder. I'll review some old logs to confirm.  This was also the first time I pull an engine with the transmission still attached. It went much better then expected. I was worried my CD009 wouldn't make it easy due to its sheer size but it was much easier this way.
    • From the pictures I have when doing the job the flywheel is the same diameter, I don't think they're playing weird tricks like putting weights at the outer diameter to increase flywheel inertia or anything like that. The OEM flywheel is definitely heavier, but it's not a huge difference. Quoted weight savings of the clutch is 2 kg so I can't imagine the flywheel being lighter than ~7 kg. Kind of regret not weighing it before the clutch went into the car but as far as driveability goes I have no complaints.
    • HKS trigger kit should be very easy to integrate with a Link. It's a 36-2 crank trigger. Hard part is finding the motivation to take off the timing belt and everything on the front of the engine to install it. You also need to cut out a hole in the oil pump housing so the sensor can read the trigger wheel. Changing out the cam sensor for a 24 tooth setup is probably good enough but as others have mentioned depending on what underlying assumptions are changed it becomes more of a problem. Reading the crank state off of the cam is an abstraction that works in the general case, but if you have an edge case it makes less and less sense. There is a GTX2860 gen 2 that can take a compact 5 bolt housing so it's direct bolt on but I'm not 100% sure of what's involved. Peak compressor efficiency drops off a bit on these turbos vs -5s, 77% vs 73% but you get way, way wider region of operation. The -5s have a really strange surge line in their compressor map that is all over the place. If you think the hot side on the -5s aren't open enough you can try the Tomei T550B turbos which a local tuner seems to be happy with:
    • i need a complete tail light for my R33 GTR if you have please let me know.
    • I need a great maintenance workshop around Idaho, if you know one please let me know..
