i agree, but id still want something like that lmao
dudes, my rb20 turbo off my dead engine, stuck my singer into the intake where the impeller is and felt an edge, like its been machined, this normal? pat?
You stuck your what into the intake? Wait... I don't want to know the answer to that haha
No idea, a hi flow rb20 turbo would only get you 200kw. Although responsive it would give the same power as a stock rb25 turbo.
Had a hiflow rb20 turbo but didn't bother fitting it, rebuilt a hks2530 instead
would want to make a responsive 320kw on low boost for street and 400+ on high boost for track later down the track.
With the amount of attention to detail and work which you are putting into the car, the last thing you want to do is slam it into the wall because of an oil spill on the track (happened to my friends restoration car)
You decide now; is it a track hack with no care for panels or a Clean streeter? The choice you make now will save you heartache in the future.
lol wrong way round mate... your track tune is meant to be the one with LESS power
try driving 300 before you decide on 400 lol
lol true... 3oo at the rears is one hell of a drive in a 1.3 tonne car that knowing moh will be low and stiff.
dont get me wrong, i LOVE my car and it's 3oo rwkw however it's not something you need lol.
i'd be happy with ~250 in a car that weight and you could wrangle a 20 to get that
driving a 3.0 with 300+ is basically just a controlled crash from the moment you touch the accelerator
id probably cry if i crashed it...
:/ what i dont even
i kinda want to continue the GTR look, and drop a 26 in it... dont want it to be a 4 door 32 thats just had guards put on, if you get what i mean
im not going bellow legal on this..
id be happy with just a stock 26... but the 30, is more of a why not..
Well said...
That's what I'm still deciding with my R33: track basher and let it go au naturale, or fix the hail damage with a full respray and keep it nice. Either way, my wallet loses.
Guest
    • Got the motor out and torn down. I'll be dropping off the block Monday. Luckily the scoring on Cyl6 is much less pronounced then the pictures made it out to seem. It can barely be felt. If you pass your finger over it 10x you'll barely notice it. Hopefully by some chance it will only require a honing. I'm not in the mood to buy one size larger pistons or another block. Oddly enough my 6th cylinder with the scoring has extremely clean intake valves compared to my other 5 cylinders. I'm worried the scoring was caused by too much fuel or Water/Methanol washing the cylinder. I'll review some old logs to confirm.  This was also the first time I pull an engine with the transmission still attached. It went much better then expected. I was worried my CD009 wouldn't make it easy due to its sheer size but it was much easier this way.
    • From the pictures I have when doing the job the flywheel is the same diameter, I don't think they're playing weird tricks like putting weights at the outer diameter to increase flywheel inertia or anything like that. The OEM flywheel is definitely heavier, but it's not a huge difference. Quoted weight savings of the clutch is 2 kg so I can't imagine the flywheel being lighter than ~7 kg. Kind of regret not weighing it before the clutch went into the car but as far as driveability goes I have no complaints.
    • HKS trigger kit should be very easy to integrate with a Link. It's a 36-2 crank trigger. Hard part is finding the motivation to take off the timing belt and everything on the front of the engine to install it. You also need to cut out a hole in the oil pump housing so the sensor can read the trigger wheel. Changing out the cam sensor for a 24 tooth setup is probably good enough but as others have mentioned depending on what underlying assumptions are changed it becomes more of a problem. Reading the crank state off of the cam is an abstraction that works in the general case, but if you have an edge case it makes less and less sense. There is a GTX2860 gen 2 that can take a compact 5 bolt housing so it's direct bolt on but I'm not 100% sure of what's involved. Peak compressor efficiency drops off a bit on these turbos vs -5s, 77% vs 73% but you get way, way wider region of operation. The -5s have a really strange surge line in their compressor map that is all over the place. If you think the hot side on the -5s aren't open enough you can try the Tomei T550B turbos which a local tuner seems to be happy with:
    • i need a complete tail light for my R33 GTR if you have please let me know.
    • I need a great maintenance workshop around Idaho, if you know one please let me know..
