Lol so I've bought a gtx3071r and estimating around 300rwkw. I probably will kill myself, but I don't think it will too as responsive as yours with 300kw for say. Should be fun
definately not considering a 3071 .86 is less responsive than mine on a 2.5 anyway let alone a 2.0 ;)
Yeh going on with a .82 to begin with because it's there. But might go .63 if it isnt responsive enough
stock 26 + n1s and a tune?
26 isn't that good man...I drove one the other day with the same power as my 25, it wasn't any less laggy getting on boost. Left me disappoint after high expectations. Whatever cool, original shit you want to do with your car engine wise...it's all been done before. People have put 1JZs in Skylines lol. Just do the most practical and cheapest thing that most people do and junk a 25 in there.
26 isn't that good man...I drove one the other day with the same power as my 25, it wasn't any less laggy getting on boost. Left me disappoint. Whatever cool, original shit you want to do with your car engine wise...it's all been done before. People have put 1JZs in Skylines lol. Just do the most practical and cheapest thing that most people do and junk a 25 in there.
A 25 neo would be good will have some transient response with the variable timing too!
this.
Anything wrong with buying a 2nd hand bike jacket assuming it's in near new condition? Let's say rrp is ~$1k and I can get it for less than half price
Or for the same price get something not as good but brand new?
/bikes
Couldnt see a problem with it as long as it fits and is in good condition
What jacket is it?
Oh then what's the diff between neo and 33 liner?
Just get a 25 moh out of all people I don't think YOU would notice the difference in 100cc lol
R34 turbo has a bigger rear housing and something else ECU related I think.
/bikes
Nah that's fine, it's not like buying second hand helmets. If it fits go for it.
/bikes
oh thank god. i was starting to think this forums was about skylines.
Guest
    • Got the motor out and torn down. I'll be dropping off the block Monday. Luckily the scoring on Cyl6 is much less pronounced then the pictures made it out to seem. It can barely be felt. If you pass your finger over it 10x you'll barely notice it. Hopefully by some chance it will only require a honing. I'm not in the mood to buy one size larger pistons or another block. Oddly enough my 6th cylinder with the scoring has extremely clean intake valves compared to my other 5 cylinders. I'm worried the scoring was caused by too much fuel or Water/Methanol washing the cylinder. I'll review some old logs to confirm.  This was also the first time I pull an engine with the transmission still attached. It went much better then expected. I was worried my CD009 wouldn't make it easy due to its sheer size but it was much easier this way.
    • From the pictures I have when doing the job the flywheel is the same diameter, I don't think they're playing weird tricks like putting weights at the outer diameter to increase flywheel inertia or anything like that. The OEM flywheel is definitely heavier, but it's not a huge difference. Quoted weight savings of the clutch is 2 kg so I can't imagine the flywheel being lighter than ~7 kg. Kind of regret not weighing it before the clutch went into the car but as far as driveability goes I have no complaints.
    • HKS trigger kit should be very easy to integrate with a Link. It's a 36-2 crank trigger. Hard part is finding the motivation to take off the timing belt and everything on the front of the engine to install it. You also need to cut out a hole in the oil pump housing so the sensor can read the trigger wheel. Changing out the cam sensor for a 24 tooth setup is probably good enough but as others have mentioned depending on what underlying assumptions are changed it becomes more of a problem. Reading the crank state off of the cam is an abstraction that works in the general case, but if you have an edge case it makes less and less sense. There is a GTX2860 gen 2 that can take a compact 5 bolt housing so it's direct bolt on but I'm not 100% sure of what's involved. Peak compressor efficiency drops off a bit on these turbos vs -5s, 77% vs 73% but you get way, way wider region of operation. The -5s have a really strange surge line in their compressor map that is all over the place. If you think the hot side on the -5s aren't open enough you can try the Tomei T550B turbos which a local tuner seems to be happy with:
    • i need a complete tail light for my R33 GTR if you have please let me know.
    • I need a great maintenance workshop around Idaho, if you know one please let me know..
