lol true... 3oo at the rears is one hell of a drive in a 1.3 tonne car that knowing moh will be low and stiff.
dont get me wrong, i LOVE my car and it's 3oo rwkw however it's not something you need lol.
i'd be happy with ~250 in a car that weight and you could wrangle a 20 to get that
driving a 3.0 with 300+ is basically just a controlled crash from the moment you touch the accelerator
the old sedan had 235rwkw on a high flow garrett, dual ball bearing so lag wasnt a big issue, but even that got sketchy many times
i thought that was plenty for street in a 32
lol after driving alvins old GTR.... so much want
and that was a couple months after i got my license, alvin you crazy kent
I had a NSW guy (can't remember who) that rode in my car to one DECA when it was at 235kw, said it would compete to his 260awkw for power to weight
so don't knock the 20 off straight away, they take a good beating too
I would just work it and enjoy it
I can't decide who's more retarded...
Mohsen, or the rest of you for still thinking you can talk sense into Mohsen
HAHA
Nice work for the vic r33 owner stealing fuel and posting it on youtool for aca to show tonight
Red r33 rego "jail me " really asking for it ????
Disgusting
Qoute, "i'm bored" really pathetic
How about digging ditches on a chain gang in 40+ heat while bubba calls you his bitch
Disgusting
Who the f**k are you?
Guest
    • Got the motor out and torn down. I'll be dropping off the block Monday. Luckily the scoring on Cyl6 is much less pronounced then the pictures made it out to seem. It can barely be felt. If you pass your finger over it 10x you'll barely notice it. Hopefully by some chance it will only require a honing. I'm not in the mood to buy one size larger pistons or another block. Oddly enough my 6th cylinder with the scoring has extremely clean intake valves compared to my other 5 cylinders. I'm worried the scoring was caused by too much fuel or Water/Methanol washing the cylinder. I'll review some old logs to confirm.  This was also the first time I pull an engine with the transmission still attached. It went much better then expected. I was worried my CD009 wouldn't make it easy due to its sheer size but it was much easier this way.
    • From the pictures I have when doing the job the flywheel is the same diameter, I don't think they're playing weird tricks like putting weights at the outer diameter to increase flywheel inertia or anything like that. The OEM flywheel is definitely heavier, but it's not a huge difference. Quoted weight savings of the clutch is 2 kg so I can't imagine the flywheel being lighter than ~7 kg. Kind of regret not weighing it before the clutch went into the car but as far as driveability goes I have no complaints.
    • HKS trigger kit should be very easy to integrate with a Link. It's a 36-2 crank trigger. Hard part is finding the motivation to take off the timing belt and everything on the front of the engine to install it. You also need to cut out a hole in the oil pump housing so the sensor can read the trigger wheel. Changing out the cam sensor for a 24 tooth setup is probably good enough but as others have mentioned depending on what underlying assumptions are changed it becomes more of a problem. Reading the crank state off of the cam is an abstraction that works in the general case, but if you have an edge case it makes less and less sense. There is a GTX2860 gen 2 that can take a compact 5 bolt housing so it's direct bolt on but I'm not 100% sure of what's involved. Peak compressor efficiency drops off a bit on these turbos vs -5s, 77% vs 73% but you get way, way wider region of operation. The -5s have a really strange surge line in their compressor map that is all over the place. If you think the hot side on the -5s aren't open enough you can try the Tomei T550B turbos which a local tuner seems to be happy with:
    • i need a complete tail light for my R33 GTR if you have please let me know.
    • I need a great maintenance workshop around Idaho, if you know one please let me know..
