Yeah just wait and see what the contract says.
Be careful where you get your tax advice.
If your salary sacrificing you cannot double dip and claim a tax deduction. Also in regards to the MV this > 50% thing is fairy tales. If you are using 1% of your MV for business use then you claim 1% (log book method),
My charge out rate is $400/h. Give us a ride in a C63 and will call it even :P
Yeh if it's supplied no tax claim anyway. And no paying from me. If I have to pay for it I'm just not going to get it. No point having two cars, if they don't want me rocking up in a bright orange Silvia then they can give me a car lol it wasn't a prerequisite to have a "classy car" when I applied for the job
Haha I bet the orange car would sure make an impression.
I get some odd looks whenever I need to drive my car into the factory loading area. Especially with the sticker bomb fuel cap.
yeh i get looks from everyone.. ill take a picture of the parking lot and post it tonight.. everything is black silver or grey..then BAM bright orange lol i get complimented by the managers aswell...
oh ive already conformed. i think the merc's are amazing.. and really comfortable.. would i buy one ? no.. i have better things to spend $70k+ on.. but would i drive it if given to me? if i got a hyandai for free i'de drive it..
$400 per hour I call shenanigans lol
Lol it's actually quite a reasonable rate compared to other high-end firms
Better not be charging me that rate for my tax return!
I have a cheap special wastelands charge out rate
Looks like i'll be doing a few. Happy to help my brahs out
I pay my dude like $600~ that's it.
And he takes 1 1/2 hours to do your tax return. Jokes brah :P
Go to the CBD and book an hour with a Tax Manger at somewhere like Pitcher Partners or Ernest & Young, and the charge out rate would be $600-$1,000 an hour.
Not that you need that, as a Graduate Accountant can prepare a simple Tax return. Just sayin :P
Guest
    • Thanks Duncan! Yeah it's street use for me only. Maybe occasional track day. Any difference in noise when running with the two pumps? I would expect the lift pump to be more quiet than the main pump so hopefully not? And yes, unfortunately quite a big price difference to the simple hanger setup. Though I'm usually willing to trade money for better reliability and future-proofing. Buy once, cry once and all that. I'd be very happy to never have to deal with fuel pump / wiring issues again
    • The old manifold was quite under the GTR strut brace.  The new manifold is quite [unknown] the GTR strut brace. The GTR strut brace was needed to clear the bonnet vents. The Old strut brace will almost certainly clear the new manifold, but not the bonnet vents. The old strut brace will almost certainly clear the new manifold, and the new bonnet without vents. But I am hoping the GTR strut brace clears the new manifold :p
    • On the bright side, at least you knew that it happened and remedied before anything happened. A friend of mine just took his Fiat 124 to a shop for an oil change and they didn't tighten the oil filter housing properly. 4.5 quarts spewed out and even after refilling + tightening the cap the engine has a tick now.
    • So, more pain. The FAST manifold is a little larger than the stocker. This is problematic because there really wasn't much clearance to begin with, so going from 'barely enough' well into 'no' is sad based on the external dimensions of the thing, even though where it bolts to the head is the same. Result is the fuel rails sit a good 25mm higher, and this is a bit of an issue with the wiring that runs behind the motor, and the fuel lines, and everything else. When pushing the manifold on, it required a huge amount of force to crush wiring looms to fit it, sensors like the MAP sensor are about 1mm from the firewall, and the FPR just has to bend ABS lines to be forced into place. After some brainstorming and some sad drinking, the loom for some reason ran from the grommet behind the ABS sensor, then to the driver side head, then back to the passenger side head. So all of this was pulled back and stripped, a few wires cut and rejoined, so that the 'branch' was now on the passenger side's head as below: Before you basically couldn't see anything behind the driver head. This is much improved! The MAP sensor is now pointing up (instead of at the firewall) Brackets have been made up for the rail. The rails are for a LS1, the manifold is designed around a LS2 as it's base. Which of course has slightly different bracketry and water pump clearance, hence the mods people need to do. Should be hopefully mounted tonight. I spent money on a new FPR that is slightly more compact than my Turbosmart FPR1200. The gauge has also been moved to the rail. There's also apparently an ORB to AN Union instead of the adapter, because the ~25mm of the current adapter is going to make the difference. Provided this all goes together and arrives today, it'll be the totally not stressful attempt to start it.
