How does a RB26 look 'factory' in a 4 door R32 GTS-T unless you drove an Autech R33 GTR 4 door..?
look at it this way, to them its all the same shit, and my car looks like a GTR just with extra doors
so it should work, then later down the track id get it engineered and not give any f**ks.
i do give a small amount of f**ks now, but not too many
today is friday, i give 10 f**ks. who wants sum f*k?
You really were dropped on your head as a child lol
I see.
Yeah engineers cert would help out.
i used half a pen worth of ink on yesterday's paper.
amazing how much they expect you to write in 2hours.
haha laters. dunno about ink, but go through a fair few leads, as i use my pacer like a baws! although today's exam specifies that i need a 4 colour pen and a3 graph paper for drgs... of course not provided. cheap f**kers!
Edited by kaitoukid
assuming he can find an engineer who'd sign off on that cert, i'm an engineer, just the wrong kind.
Haha!
Man, if you could sign engines off, I'd be seeing your workshop for some crazy engine mods :D
i think you might have been thrown at a wall...
I see.
exactly... which is why i dont see why this is so retarded... im guessing everyone else whos done a swap is also a retard..
Lol because I'm the one That bought a gtst and trying to make a gtr..
im actually trying to make a GTB4. top bloke
Engineers does SFA against an EPA.
man f**k this state. ill find a way.. dont worry
Guest
    • Got the motor out and torn down. I'll be dropping off the block Monday. Luckily the scoring on Cyl6 is much less pronounced then the pictures made it out to seem. It can barely be felt. If you pass your finger over it 10x you'll barely notice it. Hopefully by some chance it will only require a honing. I'm not in the mood to buy one size larger pistons or another block. Oddly enough my 6th cylinder with the scoring has extremely clean intake valves compared to my other 5 cylinders. I'm worried the scoring was caused by too much fuel or Water/Methanol washing the cylinder. I'll review some old logs to confirm.  This was also the first time I pull an engine with the transmission still attached. It went much better then expected. I was worried my CD009 wouldn't make it easy due to its sheer size but it was much easier this way.
    • From the pictures I have when doing the job the flywheel is the same diameter, I don't think they're playing weird tricks like putting weights at the outer diameter to increase flywheel inertia or anything like that. The OEM flywheel is definitely heavier, but it's not a huge difference. Quoted weight savings of the clutch is 2 kg so I can't imagine the flywheel being lighter than ~7 kg. Kind of regret not weighing it before the clutch went into the car but as far as driveability goes I have no complaints.
    • HKS trigger kit should be very easy to integrate with a Link. It's a 36-2 crank trigger. Hard part is finding the motivation to take off the timing belt and everything on the front of the engine to install it. You also need to cut out a hole in the oil pump housing so the sensor can read the trigger wheel. Changing out the cam sensor for a 24 tooth setup is probably good enough but as others have mentioned depending on what underlying assumptions are changed it becomes more of a problem. Reading the crank state off of the cam is an abstraction that works in the general case, but if you have an edge case it makes less and less sense. There is a GTX2860 gen 2 that can take a compact 5 bolt housing so it's direct bolt on but I'm not 100% sure of what's involved. Peak compressor efficiency drops off a bit on these turbos vs -5s, 77% vs 73% but you get way, way wider region of operation. The -5s have a really strange surge line in their compressor map that is all over the place. If you think the hot side on the -5s aren't open enough you can try the Tomei T550B turbos which a local tuner seems to be happy with:
    • i need a complete tail light for my R33 GTR if you have please let me know.
    • I need a great maintenance workshop around Idaho, if you know one please let me know..
