lol, i'm not working now so thought i'd give it a miss.. but i'll shave just for you <3
coming out tonight?
I'm at a mates house and I'm hugely tired, my only driving will be Mario Kart :) Ride tomoz if it's dry?
haha yeah bro, anytime. sort of. still have two exams left haha, will be really free after the 19th! hopefully the weather clears up too ! :D.
but depending on how lazy i'm feeling (towards study) possibly up for it beforehand xD.
lol that's what i thought. would certainly be impressive economy for a car with some performance :P
haha you would be surprised how well the tdi goes, especially that its 2litre and been tuned :P
WUT! Da Faq!
Yanks always gotta push it that one step further :laugh:
s13 convertible with 32 front
Haha really? figured they were zippy, but yeah :P. always looked at R32's and GTI's (and now R's). Only can drive R32 though, and that's too $$$ for me :(.
Mate has a smaller engine mk6 tdi or tsi... tells me about his economy and i go cry in a corner
Last exam on the 20th here. And I haven't been studying at all... LOL
Leggo cruise tonight!
OK THEN rofl. Dunno how long can come out for, but why not :P. Will regret later.
Edited by kaitoukid
OK THEN rofl. Will regret later.
Your able to drive any of the tdi's as well, because it's diesel its not classed as performance
the r32's have limited tuning too unless you drop big $$ into turbo or supercharger kits being a NA 6
Ah yeah. I sort of meant out of the box. R32 was the one of choice since no gti.
Aaron, those 275's do nothing for you. With that camber, you only have half of the tyre on the ground (could see the wet part of the tyre)
.5" smaller or more offset, less camber, and you'll have way more tread on the ground.
Guest
    • When's the rear mounted turbo kit coming? Needs dose and V8 chop idle lol.
    • I was very unimpressed with how the car came up from the A pillar forward, before I hit things (twice). It all has to go. It had to go, but now it has to go... more. So we finally found the very first Shennanigans with the entirely perfectly setup engine that had no problems being pulled apart to improve on 'was perfectly fine'. Cam bearings looked a bit... stock. Which isn't entirely bad given they were stock and this is a ~20 year old engine. So new cam bearings are on the way because it's somewhat difficult to get to this stage to do it later, and it will trash the block. It was quite unusual that it wasn't done when the perfectly new-looking VCM cam was originally installed by [unknown] What IS unusual is the cam that was installed there was advanced SIX degrees. As to why there is no way to know.. however it could have been @Dose Pipe Sutututu's mate who wanted a larger cam sound but also wanted it to come on earlier to be more usable. This is my dyno sheet with the previous setup - This cam is not supposed to peak until 7000+ RPM, according to VCM. This is what lead me down the whole 'my heads/intake setup is running out of puff and can't support the cam' line of thinking to begin with. Anyway too late now - New cam is in! It could be rather funny if this smaller cam acts like a larger cam because it isn't advanced six degrees. In the spirit of everything is working amazingly - the COMP cam required no dialling in whatsoever. It was about 0.5 degrees advanced, which seems pretty bang on. Any adjustment either way would be further out. I'm told as a chain breaks in it ends up regarding back about 0.5 a degree as the chain breaks in, making it bang on. In the spirit of everything was previously working amazingly - The timing gear that was taken out turned out to be was an N-Motion double timing chain kit, with adjustable cam gear (which is how it was 6 degrees advanced) and all looks entirely perfectly new. It also had a Torrington bearing, which was one of the reasons I ended up getting the Cloyes kit which they used in the C5R 24 hour racecar - Because I couldn't confirm what was in the engine when talking to Tony Mamo. I did believe however it was a Double chain kit of some kind... but found no supporting documentation or evidence for it.
    • I recently did this to my R33 with the full set from Car Mats Direct, they can't do the vinyl anymore that's advertised on the website due to a supplier issue so I ended up with the Black Loop Pile which looks great. I went all out with rubber sound deadening sheets from Repco and also added the sound deadening foam layer option with the carpet. Makes a world of difference and got rid of all the weird smells in the 29 year old interior. It was a bit of work but I'd 100% recommend it, Car Mats Direct had awesome customer service and quick postage. Replaced my seats with some sporty ones from Autotechnia while I was at it, feels like a new car.
    • Got the motor out and torn down. I'll be dropping off the block Monday. Luckily the scoring on Cyl6 is much less pronounced then the pictures made it out to seem. It can barely be felt. If you pass your finger over it 10x you'll barely notice it. Hopefully by some chance it will only require a honing. I'm not in the mood to buy one size larger pistons or another block. Oddly enough my 6th cylinder with the scoring has extremely clean intake valves compared to my other 5 cylinders. I'm worried the scoring was caused by too much fuel or Water/Methanol washing the cylinder. I'll review some old logs to confirm.  This was also the first time I pull an engine with the transmission still attached. It went much better then expected. I was worried my CD009 wouldn't make it easy due to its sheer size but it was much easier this way.
