to be honest, nothing groundbreaking or even adventurous. i got a build thread if you wanted to check out some minor changes. http://forum.pulsar....lsar-Adventures
Just want to have some fun and learn to drive real good.
people were upset to see your N15 go, but im sure the Cube is going well :)
Will check out your thread, cheers :)
Yeah I know I upset a lot of people by parting out and selling off my car but in the end it was something I needed to do. And a little bit of my Pulsar is in so many other high profile Pulsars now so it lives on in spirit hehe :) I still stumble across it all over the 'net. If you ever come to the point of having to sell your car - part it out. I made back more than what Steve sold his car to you for and his was more modified than mine was ;)
interested in the pan fried cheese bread :P
Where is this pasta place? Looks tasty
It's my house lol, home cooked to perfection. Maybe I should have a pasta party? (with cheese bread)
My bad, you are right; you can use beef. We'll try it with the wagyu lol.
<3 parmesan Moh...though people come home and complain that the house smells like vomit lol.
well you havent beaten this guy yet though.
he used the oven to heat up ONE wicked wing, and forgot about it. who the hell heats up one wicked wing?
it became charcoal, and made the whole house smell of burnt flesh.
in a microwave, anything less than 100g. 1min on high.
do you grate the parmesan yourself?
When I have real parmesan I grate it, but most of the time I use Kraft longlife dried/dehydrated parmesan - the taste is much sharper than with regular parmesan.
Guest
    • My understanding is that UV tends to accelerate the aging process. If the car has been garaged, then you could probably get away with extending beyond 10 years. FWIW, in 2015, I had tyres on my 180B SSS that had a 3-digit code (2 for week, 1 for decade), ending in 0, so could have been more than 30 years old, but still worked fine. I did replaced them very quickly, though, once I discovered what the code meant!
    • But we haven't even gotten to the point of talking about stateless controllers or any of the good stuff yet!
    • You guys need to take this discussion to another thread if you want to continue it, most of the last 2 pages has nothing to do with OP's questions and situation
    • And this, is just ONE major issue for closed loop control, particularly using PID. One such issue that is created right here, is integrator wind up. But you know GTSBoy, "it's just a simple PID controller"...
    • Nah. For something like boost control I wouldn't start my design with PID. I'd go with something that originates in the fuzzy logic world and use an emergency function or similar concept. PID can and does work, but at its fundamental level it is not suited to quick action. I'd be reasonably sure that the Profecs et al all transitioned to a fuzzy algorithm back in the 90s. Keep in mind also that where and when I have previously talked about using a Profec, I'm usually talking about only doing an open loop system anyway. All this talk of PID and other algorithms only comes into play when you're talking closed loop boost control, and in the context of what the OP needs and wants, we're probably actually in the realm of open loop anyway. Closed loop boost control has always bothered me, because if you sense the process value (ie the boost measurement that you want to control) in the plenum (after the throttle), then boost control to achieve a target is only desirable at WOT. When you are not WOT, you do not want the the boost to be as high as it can be (ie 100% of target). That's why you do not have the throttle at WO. You're attempting to not go as fast as you can. If the process variable is measured upstream of the throttle (ie in an RB26 plenum, or the cold side pipework in others) then yeah, sure, run the boost controller closed loop to hit a target boost there, and then the throttle does what it is supposed to do. Just for utter clarity.... an old Profec B Spec II (or whatever it is called, and I've got one, and I never look at it, so I can't remember!) and similar might have a MAP sensor, and it might show you the actual boost in the plenum (when the MAP sensor is connected to the plenum) but it does not use that value to decide what it is doing to control the boost, except to control the gating effect (where it stops holding the gate closed on the boost ramp). It's not closed loop at all. Once the gate is released, it's just the solenoid flailing away at whatever duty cycle was configured when it was set up. I'm sure that there are many people who do not understand the above points and wonder wtf is going on.
