All cars are like that not sure why but never seen a car that doesn't have one wheel in more than the other
Ive heard its due to the diff being slightly offcentre or the subframe it self being slightly offcentre.
Car manufacturers never expected owners to be running wheels so close to the guards that you can tell the difference haha
I don't understand how any of this makes sence, the allignment tools have Indipendang levels in them. If its out, it's out.. Unless there is some auto correction when you put the specific car in..
But birds what you said doesn't make sence because how are they going to compensate for fat dream boats like me?
I think what Alex and I are talking about is the offset of the wheels to guards. Majority of the time, one wheel will sit out more than the other side. The camber setting would probably be the same on both sides hence why one side would look slightly different in reference to the guard/body etc
i dont know, its friday.
Well when I got my car alligned at Centreline...and mind you I have adjustable poly bushes on just about the whole frikken car...they corner weighted it and alligned it so that with an ~80kg driver, there is a near 50/50 side to side weight distribution and the camber sits about the same on both sides. Sucks when you have a passenger and can tell the difference though...
This and what birds said I think the thing is off centre so even though the camber is the same the actual wheel position is out a little bit on one side even although the camber settings are the same.
Shitted me with the 33, but no two guards are rolled perfectly the same either which probably doesn't help
Guest
    • The issue now is the 'fuel cut' while driving, and when it happend, it does not stall. This, I did not test the fuel pressure while driving as I cannot with a fuel pressure gauge. I do have Nistune logs, yes. I have also replaced the MAF Sensor.   Also related to the FPG Fuel Hanger – I just realized that I need a Deutsch Crimp Tool to crimp some cables for the FPG Fuel Hanger. Need to purchase additional cables as the kit only included 2, which are for the float. FPG has not responded to my emails so far since purchasing. I thought about taking it to someone and having it done professionally, but I am reluctant since everyone I took it to messed up in some way.
    • There's a good German place in Brisbane if youre up for the drive 😛
    • The German place in Cabramatta was rock solid, fresh pretzel cooked to order back then. Then it went all quiet, after all the poker machines were removed, then I believe it closed for good. I did drive past the other week and noticed outdoor lighting a big screen, but no idea what is there now.
    • Yeah I suspect even if you hold airmass per cycle/cylinder constant if you get too far away from stock you're still going to have problems running the factory tune within the bounds of the factory load scale. Cams, different displacement/rod ratio, etc. I'm just lucky that the GTIII-SS with wastegate boost + CA compliance cats is pretty much equivalent to stock turbos. When I have actual space I can finally get it tuned and modify the fuel system for flex fuel to 100% handle any detonation concerns when cranking the boost to whatever those dinky turbos can put out.
    • I would say no, why, because my daughter, who also lives in Goulburn, hasn't recommended us going there Pity, as we miss all the German joints around in Sydney, actually, the restaurants are the only thing I really miss about Sydney, and a special mention to Ishibanboshi at Bondi Junction, their Kara-age Don is heart cloggingly deliciousness (always added a special boiled egg...or 2) 😋
