I actually prefer work :P
Brain is normally shut down at 5p.m
Where if you study you always need to worry about assignments, exams etc...
And getting paid is a bonus!
Working for family business is always on go for me, but then again it's not a normal 9-5 job I have
No offense to people here but I can't stand uni whingers clueless pricks 99% live at home got no idea about the real world moanin about assignments and tests
Fk that try getting a job keepin a job paying bills food on the table it's not 1/10 of surviving in the real world especially the current climate for gettin and keeping a job
I don't even get a 'wage' I can go a month and earn $0 .. Actually I'd owe the business money don't here me bitchin n moanin
/csb
I can't stand any whingers... sure everyone gets pissed off at times, including me, but if you're so unhappy then change it or shush.
This, people need to harden the fark up. Life is hard yes, but you have to enjoy what little we really have of it
so if your unhappy, change something to be happy.
Got reports that in Seymour things were falling off shelves... city area obviously didn't get the brunt of it. Rye didn't even feel it.
dunno, I'm only 30mins from Seymour and the house shook for 1-2 secs max
Comes down to university & field of engineering. Monash Uni was a ball breaker
This.
One of my mates in swineburne is doing 30 hours.
Another in monash is around 35.
I'm @ rmit doing 20. Don't know why, but me happy. :P
Only thing I have to say is for all those studying and doing double degrees etc.. is that it's all good as long as you do something with it.
I know plenty of brahs that do double degrees in what not, but end up getting/wanting a job that didn't need it or still end up working at Coles etc..
Also what subject you study does depend what University is best but. University of Melbourne is ranked as the #1 University in Australia and 37th in the world :P
Edit: Depends which source you read but Melb Uni might be behind Australian National University.
inb4 methodologies are crap
yeah, my prof that i was doing my final year research project for transferred to Uni of Western Syd.
Project supervisor offered me to work as a research assistance engineer for him and i turned him down thinking I don't want to hang around Uni... how stupid was i.
So close to graduating yet so far, frustrating.
Guest
    • 49719 is the cooler loop. Right at the front, LHS of that diagram. Return line from rack (LP side) goes to cooler loop on RHS front of car, then back under engine and returns to bottom of tank. 49717M is feed from tank to pump. HP line out of pump is thick rubber, followed by the hard line that runs down to crossmember and runs in parallel (but opposite flow direction) to the LP return line. Nothing goes anywhere near the firewall or interior of car. The closest they get to that is the connections on the rack.
    • Thanks, plan is to drain all fluid tomorrow and do smoke test to find out the leak.   Appreciate your help and want to understand how the system work. So cooling is achieved by the long loop not any rad? The diagram seems to suggest it connects to somewhere inside the cabin and I thought that is a cooler inside firewall. If you look at the diagram it seems to show it connects to something inside firewall. I tried chasing it but not easy unless I take loads off   i am confident pump is good as fluid goes in and it gets soft( steering) but as soon as I turn engine off , loads of bubble come to surface and overflow. When engine is on , fluid level is below minimum but when off it shoots off and thinking it is sucking air in. I suspect aluminium pipe may have a crack line or whole   smoke test with no fluid should be a good start and if needed will remove the pump   In addition, the one going under the engine bay is high pressure line and one directly connecting from pump to resorvoir is return/ low pressure?   finally I searched and suggestion is to use dexron 2 but that is discontinued so bought dexron 3 as all research suggest it is compatible and shouldn’t cause any issues/ blow seals. I bought two liter of dexron 3 motul atf
    • Don't worry about. Just don't try to drive hard enough to make boost and you'll be fine.
    • Yes. This has already been said. It is a loop of hardline in front of the radiator. Because.... the pump is on the LHS and the steering rack hydraulic connections are where they always are on a RHD steering rack....on the RHS. The high pressure line goes down under the engine, along the crossmember, like it does on all Skylines. Don't just throw expensive braided hoses/other kits at it. Work out what is wrong and fix that.
    • Still got the afm on the intake, clamps are shut tight, only loose hose is the one that goes from the j pipe towards the IACV, since it's next to impossible to find a factory hose and the barbs are different sizes (I'm still using clamps on this hose to try and help it seal on the iacv side) I've ordered parts to make up the hotside of the intercooler pipes, I'll plumb it in and see what happens in a few days I suppose The turbo's internally gated, can I just unscrew the tension rod to let the gate open?
