Think the only difference between the plus and pro glove is the hard cover on the wrist strap...Dude at Peter Stevens told me not to bother with them over the Plus..
And the Pro is $250 like the Dainese Joust....
I said I want all that, not that I can afford it.
Peter Stevens' staff are crap. hard cover on wrist = extra protection and it'll match the cover on the shoulders kthx
Will do you a good deal on the plus ;)
what colour are they?
I recommend RST gloves, way more affordable than Dainese or AStars, great quality and fit a billion times better imo. UOf course this depends on your hand shape but I find any other gloves makes my thumb to forefinger movement quite restricted. They also look sick and match other gear well.
Srsly though just get something good quality that fits well, no one is going to notice if your fashion is out of line :S
i want matching fkn gloves!
It only arrived last night. Getting rid of the Daytona tonight so that I can have the excuse to ride it tomorrow huhu
you have a daytona 675?
As a fellow Tein SS user, I'm waiting for you to be my BC comparison/test mule.
But I'm guessing it's the vice versa for you...
Squeak is getting pretty bad, I may have to fold soon.
Surely someone around here has them in an r33... anyone? To be honest I'm more likely to buy those blitz ones, for the jdm respect yo
Have heard good things about them from R33 owners, but I wanted to hear from someone who had SS beforehand. If they are any stiffer I'd rather rebuild the Teins.
BC BR are good for the price.
They are in my brothers R33 GTST. I drove it around of months while he was on deployment. Firm, but compliant.
They also did very while on the track when I wound them down.
I've since driven the car while it's been in QLD. Just as good, both on the road and on the track up there.
They are much softer than any cusco / tein japan stuff. Much more compliant than old stock suspension as well.
My Greddy Type-S are basically BC BR as well.
You got hookups for rebuilding? I've heard it is barely worth it. Confirm/deny?
I wouldn't mind going a bit stiffer, if only cos of my wheels now
It's only one coilover that's squeaking, so would be worth it price wise. Bit of a gamble, cause the others could shit themselves too...probably already worn but no visible/audible signs. I have a phone number of a mob down here, who send them to Fulcrum for rebuild...
lol @ all the Vic exec tags on this page.
Ah ok, let me know if/when you get prices. Mine are knocking a bit, not sure if I should just bin them or go new
Guest
    • CTIS (Central Tire Inflation System) has existed since the 80's. I'm looking into buying a Hummer H1 and they generally included it.
    • My idle is set at 950rpm though - Moving the timing around 20 degrees is not really what I'd call a calm idle. That said... neither is chop, by definition. The LS ECU likes to adjust timing to hold idle as opposed to air. It'd work, but generally speaking there'd be a discrepancy in the base idle and the IACV would want to move the timing around anyway to maintain said idle. I think I'm just going to keep the timing steady anyway. Preserve my engine mounts.  My aircon is now officially regassed. As the guy was reversing I noticed my reverse lights do not operate, along with my reverse cam. This is a bit distressing, because 100% of guides talk about which wire to connect to backup cams as "the goes with the [other color] wire". Often when doing conversions. Unfortunately the R34 colour wires aren't documented Unfortunately I had a T56 Magnum gearbox with it's reverse switch, which also isn't documented. Unfortunately there's definitely not documentation for people with both of these in the one car. Unfortunately I forgot. After many hours of this, I have a reverse cam and reverse lights again. The wire going through the trans tunnel to the reverse switch had broken. Upon inspection, it looks like this one wire had about 7 spade terminals and extensions in it.. for reasons I cannot possibly comprehend. I also spent the 750 hours required to clean up the wiring behind my head unit which now looks like this: This is a monumental improvement relative to what used to be there WRT triple gauges, head unit, traction control, wideband controller, and whatever the f**k OEM stuff still exists there in various states of connectivity/needed. Next step is to check in at the Exhaust shop to see/confirm how much clearance I have, to decide what mid mufflers or 'resonators' (which are just straight through, narrower mufflers) I can add and hopefully cut out a lot of exhaust leaks, pinhole, v-band or otherwise. But first step will be to 'take a look' before the next step.
    • Fark the AFM card and Nistune, Haltech Nexus S3, DBW, cruise control, flex fuel, dis dat.
    • It's most likely the bolt/bush where the cover bolts back wore and allowed cover to move forward.
    • Still haven't put the injectors and R35 AFM in so we can tune the bloody thing for the HG highflow it got mid last year! I think I can forecast the upgrade path to a bigger twin scroll, external gate, Haltech, flex setup, Samsonas, dis dat, etc will be .... a while away!
