you think thats bad?
I WAS PAYING $3640 premium for the 34...
Has anyone heard of this? Someone aware me, just saw it on FB.
'Operation Hot Rod. The p*gs have already started pulling over people if their cars look even remotely done up. They have started handing out defect notices left, right and center. Even if they find one small defect, you'll still cop a $500 fine.'
So I'm guessing the unroadworthy car fine has gone up from $299 to $500? Cot dayum....
that prompted me to look on the vicpol website....
under "our focus" the NUMBER 1 link is... "Traffic and Transit" - this sits above "community and family," "crime prevention," and "forensic services."
within "Traffic and Transit" the links (in order once again) are: "Hoon Laws," "Road Safetly Task Force," "Safety Camera Program," and "State Government Road Safety St
I am seriously disgusted at Victoria Police.
They aren't even trying to hid it now. they are literally saying on their website that Traffic Infringements and Revenue Raising is their NUMBER ONE priority now...
never mind people being murdered/raped guys.... as long as you can defect a "hoon" and raise $500
Pathetic
[/color]
thats in sydney
No it's not, I was getting chased by highway patrol through Campbellfield industrials just before
Just made set of lights so he couldn't go through, there were cops everywhere
Not that I don't believe you were getting chased, but why would a cop car let a set of lights stop them from getting you? Last guy who got me went through 4 reds to pull me over for a "random" inspection*.
*later told me he'd spent the whole afternoon pulling over anything with four round tail lights, including Pat's 32.
because golf simple as that, I do believe he did a check as well as he sped up to get plates then back off as he was checking
he got caught behind few cars because of the way I went (knew lots of traffic goes through those roads)
In any case it's still a warning to all
Guest
    • Can u check this way it works for power supply?
    • These coils draw 10amps that what i read online
    • I appreciate the detailed explanation, think I understand now. I spent the better part of last night reading what I could about shuffle and potential solutions. I had replaced the OEM twin turbo pipe with an alternate Y pipe that is separated further away from the turbo. The current one is from HKS and I had a previous pipe that was separated even further away, both have shuffle. I had heard that a divider can be welded in to the OEM pipe to remove turbulence, and figure that aftermarket pipes that are more separated would achieve the same thing. From what I read, most people with -10 turbos get shuffle due to their size, though it's a bit less common with -5s on a standard RB26. I think Nismoid mentioned somewhere it's because OEM recirculation piping is common in Australia with -5 cars. It seems that the recommendation tends to vary between a few options, which I've ordered in what I think is most feasible for me:  1. Retune the MAP or boost controller to try to eliminate shuffle 2. Install OEM recirculation piping 3. Something called a 'balance pipe' welded onto the exhaust manifolds. I don't know if kits for this are available, seems like pure fabrication work 4. simply go single turbo My current layout is as follows: Garrett 2860 -5s HKS Racing Suction intake MAF delete pipes HKS racing chamber intake piping hard intercooler piping,  ARC intercooler HKS SSQV BOV and pipe Haltech 2500 elite ECU and boost solenoid/controller HPI dump pipes OEM exhaust manifolds HKS VCAM step 1 and supporting head modifications Built 2.6 bottom end All OEM recirculation piping was removed, relevant areas sealed off I'll keep an eye out for any alternative solutions but can get started with this.  Only other question is, does shuffle harm the turbo (or anything else)? It seems like some people say your turbo shafts will explode because of the opposing forces after a while and others say they just live with it and adjust their pedal foot accordingly.
    • That worked out PERFECTLY! Thank you big time to JJ. He was able to swap me his stock diff. He drove all the way to me as well. Killer! Removal & install was pretty straightforward. The diff itself is HEAVY. So that’s a 2 man job.  Man does the car drive nice now! Couldn’t have worked out any better 👌
