Friend took on the hoggs breath challenge in ballarat. 1.1kg steak. Signed the empty plate and it is on the wall now. 3rd largest steak to be consumed in the place.
Beat it Dezz?
I would rape 1.1 kg.
hot?
also how much tax back do you get back on donations normally
/taxlinesaustralia
Average
Beat it Dezz?
Some monsters on here, I'm a small eater. Can't compete with you brahs
Beat it Dezz?
Time limit? Sides?
I did the 1kg challenge at outback jacks, but foolishly did it for lunch on a day when I wasn't feeling particularly hungry/good.... Smashed the 1kg steak without any hassle in about 15 minutes, leaving 15 minutes for the sides...but that's what got me...
I'd ordered the 500g rump there a few weeks before, which came with chips and coleslaw... So I assumed the 1kg rump in the challenge came with the same sides....But instead it came with around 500g of wedges and 500g of vegies...
at the end of the 30 minutes I had a few wedges left and a few veggies, so on a good day I think I could knock it over.
Hogs breath steak is even more tender so that'd make it a lot easier...Most of the time is spent chewing the steak...
Time limit? Sides?
yeah came with sides. Not sure what sides or time. Will find out one day. omnomnom
On another note; just chipped in for a friends birthday present :D
Just drove from the city to Flinders to care for my horses, 1km from my house I get pulled over. Car has been defected. Bald tyres.
Could have been worse.... Much much much much much much much much worse. Cop apparently knows my family and had done the fencing on our farm when I was young so fortunately his attitude was forgiving. Stuck the defect on then took photos with his iPhone saying 'it's not every day you get to defect a Merc' I had to laugh. Phew.
I need to get back to the track :(
lol!
Birds and I just came back from a ride.. down eastlink bike track :D pretty big lols when some guy was riding a push bike.. also lol @ the evo
Martin I'm a member so I can see :P and no I wont be donating my engine to a r32
damn it need to be registered.
but short of it is:
5.0L Miami Motor in Nissan Skyline R32 4 door - Track only.
Sweet Jesus. I want it.gonna sign up to see.
Lol at tattoo bitch. Anyone ever come close to tatting something like that? Not so much a face but yeah.
lol!
Funniest shit I've seen in ages man. Could not stop laughing at pushbike vigilante...did you hear him ringing his bell at us lol? Was wondering where that path finished up...casually exit path onto road again ftw.
Evo driver was a little bitch; only wanted to do rollings. I think once he stopped at the lights and saw what he was taking on, he didn't bother - did he follow you down Terrara?
f**k that shit, I came up with a tatt I wanted at 16....at 30+ and still wanted the same design I went with it
small, not visible at work, and every time I see it I like it more.
So happy
that said bloody addictive, started coming up with more that I wanted the next day.
that said the one I came up with the next day I still want 3 years later, so might do it as well.
once again will be very very non visible at work.
ok so on a random side point. ie cars.
I have a hankering to see what I can do down the 1/4 mile. I hit up calder the weekend after I got my car and never since.
was on pathetic rubber and way down on power.
any-one know what the Calder off street days are like now?
Guest
    • No need to replace the cover if it is still intact (not worn through). It would be worth checking the balancer for matching marks on the rear, but I'd assume the balancer was loose at some stage. The cam timing marks look fine, once you put the new belt on you can only be right or a full tooth out
    • Disconnecting rods! must have been an unpleasant surprise...
    • So been ocd with timing mark but checked from few angle and seems both cam are on and crank is matching as well to the slot on sump and crank pully   i noticed crankshaft cover has been robbed as per attached pic. Any ideas why? Could my balancer or harmonic be on its way out? should I replace the cover? https://ibb.co/ZR1JFYRR
    • So now doing the change and first time dealing with rb so little nervous giving engine power and potential for screwing it up When you align all marks and then remove crank bolt, timing move little I assume you can put the bolt back in once you have removed the pully to get timing to where you want?   here is pic of my both intake and exchust cam aligned, depending on angle you look they seem to be either aligned or a half tooth or so out. Any thoughts? Should you angle your face and look at each mark that way as if looking straight rather than from above as it can be misleading   <a href="https://ibb.co/ZpnhcvbF"><img src="https://i.ibb.co/HfWrGR9b/IMG-4447.jpg" alt="IMG-4447" border="0"></a> <a href="https://ibb.co/4wm2wn4q"><img src="https://i.ibb.co/JWBqWwr1/IMG-4445.jpg" alt="IMG-4445" border="0"></a>   https://ibb.co/ZpnhcvbF https://ibb.co/4wm2wn4q
    • Thanks for the reply @GTSBoy Haven't really thought of that yet, but you are right. If the hose was damaged it should be absolutely pissing by now. I'll put some heat sleeve around it for good measure since I'm already removing the line anyway.  Maybe I'll put on some of the stock hardlines if I ever fully remove the turbos again. Maybe when T51R modding the compressor housings? Might be a fun mod on GT28s for that "fake single turbo" effect.
