So I bought an R33 gearbox in Sydney. They are large and around 60Kilos. Now I want it in Melbourne. Has anyone had any joy in this area?
The names I have been given are:
Toll
Couriers Please
Pack and Send
I have a business address to drop off to.
https://www.sau.com.au/forums/topic/379897-gearbox-from-sydney-melbourne/
not in Sydney
however most companies that import stuff from China will have wooden pallets they throw away
so if you can ask whoever your buying the box from to find an importing company of some type they will most probably have ones lying around
ok the quote from those guys was stupidly low :). You guys are champions.
Next question, anyone know where to get those gearbox sized pallets from? ;)
Where did you buy from?
Also which suburb?
Get one of the guys coming to Nationals to bring it for you and collect from Shepp.
Slabs of beer = payment
LOL
Slabs of JB cans more like it for anyone who knows how heavy a gearbox is (not to mention a total cvnt to transport cause of the space it takes up and theyre not exactly easy to fit in a car) :D
Ya these gearboxes are huge lol. Flew up for the weekend and checked it out from out near Penrith, took it to my brothers house in Glebe, dumped it there and flew home :). I can get some friends to load it on but my brother doesn't have a car (heh) so going for a spin to try and spot a pallet is difficult. Even after sourcing one, sawing up a pallet is difficult because I'm in Melbourne, slabs are the order of the day here.
Don't use TransDirect. They refuse to pickup second hand gearboxes/engines because of oil spillage, even if it's a clean and drained box. They will collect if it is reconditioned or brand new, though.
www.e-go.com.au are always cheap from Vic to NSW and back. But for things in WA / the outback, TNT are a cheaper option.
I try not to do dodgies with couriers cause they have a bad habit of leaving items at unknown depots for weeks because truck drivers refuse to carry them, without having the initiative to actually tell you this...you should be right on a once off though. Courier flow chart:
Problem?
Yes - > Deliver
No - > Leave item in the corner of a depot, someone else will sort it out.
Problem?
Yes - > Deliver
i think you mean the other way around?
Problem?
Yes - Leave item in the corner of a depot, someone else will sort it out.
No - Deliver
Problem?
No - Deliver
That's Friday arvo for you :/
    • No, with a twin plate clutch flywheels and clutch pressure plate/friction disks go together. Only clutch where that isn't the case is the Uniclutch but they currently don't make a pull version for the Getrag R34, just some other cars. Personally the flywheel is as light as I'd want it to be. It already drops revs faster than I want to shift normally and I blip the throttle again to rev match on upshifts.
    • Are there any other lighter flywheels that can be used with nismo coppermix twinplate system? Id like to gave the revs pick up faster than oem
    • RB20/25 covers don’t have threaded fasteners stock like RB26 covers. They are blind rivets so I will need to drill out and tap threads. I bought some M4x6mm button heads and will report back once done if I chose correctly length wise.    have also got some loctite
    • Interesting. I've not dived into the cleanliness of the factory CAS. I'm curious if the variations are less of an issue if the OEM sensor were brand new. Optical sensors if they're starting to get dirt and crap into them as they're getting older would definitely cause issues as they age.   It's an interesting point to keep in the back of mind for me though
    • Hmm. Tough one. Without knowing where the conductivity value is supposed to sit, it's hard to know whether a standard DMM set to an available ohms setting would be able to measure anything. Ohms being the inverse of what we're talkng about and probably good enough for the girls I go out with. But if you want to go all hoity toity with a 4 wire rig - go ahead. It can only be more accurate - just in case more accuracy or repeatability turns out to be required. If you're going to the effort, just go chuck the ohm-mage probes into the car's reservoir and see if you can measure anything at all?
