Hey guys, the plan with this car is basically to run a low 14/high 13 second pass while staying completely naturally aspirated so no nitrous/SC/turbo etc and while staying in street trim, so no stripping its guts out. Kinda want to do this just to prove it can be done and to stop people from calling NA cars slow, while they can't compete with a turbo $ for $, they do quite well for what they are.
Here are the Specs:
1990 Nissan 300ZX Z32 "Slicktop"
1430kg
131.4rwkw Dyno tested(previous owner)
Mods:
2.5" Twin UAS Catback Exhaust
2.5" Custom Front Pipes
K&N Pod Filter
Go Fast Bits Underdrive Pulley
F1 Racing "stage 3" 6 button clutch
ECUtalk Consult Display Unit
Bought the car back in 2009 with a 2.5" Custom catback, UDP, Pod & standard clutch for $6200. Was a very nice looking car, atleast to me, and the motor was in perfect nick so i decided to buy it.
From when i first bought it
Not long after i bought it did i have my first go at the dragstrip, here are some photo's
After 5 runs the best i could come up with was a 15.017 @ 97.22MPH :(. My clutch was slipping on anything more then a 2500rpm launch so i had to take off really easy.
About 5 months after that my clutch decided to call it quits, held up well for a stock clutch IMO. After looking for hours i decided on my new clutch, a "Gripforce F1" racing Stage 3 Button Clutch. Oh boy did this take some getting use to for the first day, soon as i picked up the car i got stuck in peakhour traffic!
A good 1500k's had passed and the clutch had been well worn in i decided to have another crack at the drags, i HAD to get that 14 second pass!
Decided i would take it easy on my first run so i wouldn't stuff up, managed a 14.847 @ 95MPH first try! :happy: What was even funnier was that i had tried to select 4th but had trouble so i let off a bit before the finish line. Ok Second run, was really excited to see what i could get, time to see what it was capable of :D
Timeslip, a 14.6!:
Not Bad considering a lot of first gear was wheelspin and i hit the rev limiter before the finish line! :D
Video of the run
Rear tyres are chinese 235/45R17's and were set to 25psi during my runs. After taking my car to Unigroup Engineering, Yavuz concluded that i should be able to run a 14.4 Second pass with a slightly better launch as my 60footer was a pathetic 2.315 seconds.
Mods coming up:
1 Piece Lightweigh Tailshaft
Decat Pipes for the track only
Piggyback Ecu of some sort, Either an APEXi SAFC or NIStune.
Kumho KU36 Semi Slicks.
Looking to get that 60footer down to 2.1 - 2.0 to see what i can squeeze out of it, no internal work done standard heads & bottom end. I'm fairly confident it will pull a low 14 second pass, just have to wait and see, will keep you guys updated!
Edited by Super Drager
https://www.sau.com.au/forums/topic/379898-project-na-300zx/
    • First up, I wouldn't use PID straight up for boost control. There's also other control techniques that can be implemented. And as I said, and you keep missing the point. It's not the ONE thing, it's the wrapping it up together with everything else in the one system that starts to unravel the problem. It's why there are people who can work in a certain field as a generalist, IE a IT person, and then there are specialists. IE, an SQL database specialist. Sure the IT person can build and run a database, and it'll work, however theyll likely never be as good as a specialist.   So, as said, it's not as simple as you're thinking. And yes, there's a limit to the number of everything's in MCUs, and they run out far to freaking fast when you're designing a complex system, which means you have to make compromises. Add to that, you'll have a limited team working on it, so fixing / tweaking some features means some features are a higher priority than others. Add to that, someone might fix a problem around a certain unrelated feature, and that change due to other complexities in the system design, can now cause a new, unforseen bug in something else.   The whole thing is, as said, sometimes split systems can work as good, and if not better. Plus when there's no need to spend $4k on an all in one solution, to meet the needs of a $200 system, maybe don't just spout off things others have said / you've read. There's a lot of misinformation on the internet, including in translated service manuals, and data sheets. Going and doing, so that you know, is better than stating something you read. Stating something that has been read, is about as useful as an engineering graduate, as all they know is what they've read. And trust me, nearly every engineering graduate is useless in the real world. And add to that, if you don't know this stuff, and just have an opinion, maybe accept what people with experience are telling you as information, and don't keep reciting the exact same thing over and over in response.
