Basic map of RB20 is tuned for Jap fuel which was pretty much always better than 95 RON. Running on local 91 will almost certainly see you running on the knock maps, which are quite a bit richer and retarded than the normal map, and it will be a slug. And it will probably still ping, especially in summer.
https://www.sau.com.au/forums/topic/379946-rb20-on-91-fuel/#findComment-6059430
It might be possible it will chew through more fuel when running 91 running on those said knock maps, than 98.. even on 91 I wouldn't dare go up a hill or put any kind of load whatsoever on the engine (even beyond 4000rpm on a level road)
https://www.sau.com.au/forums/topic/379946-rb20-on-91-fuel/#findComment-6059521
I have run 91,95,98 and some other crap with 98 to make it higher octane. At the time I had a stock turbo and a power fc. Basically with running 91 I had to take out about 6 degrees from memory so it wouldn't knock. It wasn't a hell of a lot slower but it was still fairly noticeable. Considering there is only a 5 dollar a tank difference between 91 and 98 when you fill up, you should use the good stuff.
If you have a stock computer definitely use 98 or better.
https://www.sau.com.au/forums/topic/379946-rb20-on-91-fuel/#findComment-6059779
yep, if you tune for it (or remap for it) its fine
but it will be sluggish and youll be limited to a low amount of boost
so if you are ok with that, go for it
but imho it would be pretty dull and sluggish
https://www.sau.com.au/forums/topic/379946-rb20-on-91-fuel/#findComment-6059893
