I am hoping someone knowledgable with installing various engine management systems into cars other that skylines can offer some advice... Yes I know it's not a Skyline!!!
My dad has just bought a E30 BMW as a project car with the 2L straight six in it, he is going to turn it in to a track car. We are going to probably get a gt3071r turbo for it with a 0.64 rear on it, with a cheap Chinese exhaust manifold to suit.
Question is, what would be a decent but reasonably priced engine management solution to suit such a car with that turbo and supporting bits and pieces?
Another thing, I had a look at it tonight and it's got a distributor... How difficult would it be to hook a CAS from say a skyline up to it and then (with an engine management system) try and convert it to individual coil on plug ignition?
Thank you.. :cheers:
how much power are you going to be pushing this engine? the Vipec V44 will run this engine with ease with the distributor.
If you are not going to need to lean on the ignition system there is no real reason to change the triggers, also if you must change them look at the other trigger systems available, ie crank triggers.
I just did an E30 Racecar. If its a later E30 it will have Motronic CAS, if its an early model just buy the Motronic CAS from a wrecker. I used a Haltech Platinum and find them unbeatable.
Is the Dizzy on the nose of the cam or in the side of the block? If on the front of the Cam its got the motronic Trigger.
Edited by N I B
I'm not really sure what it will do! 220rwkw would be nice as it's a light little car. Thanks for the info :cheers:
Yep it's got the Motronic ECU, distributor is on the end of the cam at the front. Good to hear you got one running with the Haltech, another possible option. I am actually now thinking a full replacement ECU might be overkill for his requirements. I came across this kit:
http://millerperformancecars.com/index.php?page=shop.product_details&flypage=flypage.tpl&product_id=65&category_id=45&vmcchk=1&option=com_virtuemart&Itemid=30
might even give that a try, a cheap and dirty solution to get more fuel into :action-smiley-069:
Anyway thanks for the info everyone. Back to Skylines now!
:domokun:
    • I have a heap that i have collected if you want some authentic ones still. Pm me if your interested!
    • Hey lads, reviving an old thread.  As an update, since the last time replied to this thread, ive done mostly suspension. Havent touched the motor except for maintenance. Though upon changing spark plugs, found out i had splitfires pre-installed! Updates: - Got me some stock airbox top cover and snorkel to fit onto the original intake. Should be free of defects - Bought a set of R34 GT-T brakes (not installed yet, going to rebuild + respray in champion blue + white 'Nissan' text) - Bought the last set of bilsteins from @Sydneykid and had them installed. Has been making some sounds on the rear but hopefully should be sorted out after this New Year break. - Regreased front caster rod bushings (poly bushes..) - Rear upper camber arms - Whiteline sway bars (BNF27Z 22mm + BNR11XXZ 24mm).  The rear sway bars are a bit short (ive read 50mm else where) but was still able to get them in.  Anyhows, I reckon suspension is sorted now. Maybe replace bushes (do have a set of front upper control arms from SK not installed yet) but should be okay for now. From now, I'm wanting to start working on the motor, drivetrain etc etc. Still debating on the order to go on and what to buy etc but: - ECU ( Haltech or Link ( Link states that it dont support A/T or AWD functions... Can anyone attest to this? ) - Highflow turbo ( ATR43ss2 ) - Intercooler ( Not decided yet, but cant find many good afoordable ones. Toshi says to opt for crossflow Japanese. Bit difficult this one, unless I get a returnflow Blitz from JJ? ) - Injectors ( Any recommendations ? I do have a nismo FPR ( Thanks SK ) ) - Seats - Tune by either Toshi or DVS To be fair, I did consider just keeping the stock turbo and nistuning it. Sat in a mates stock N, that had something like 200kw, and I reckon that felt more than enough. Maybe I should just go this route ahhaha. Too many choices.... Planning a trip down south, so wanting to just clean things up and make sure it gets to and from in one piece. Anything else specifically I should do before ? Cheers lads
    • Must be for the car’s lucky charm 🤷🏽‍♂️ She runs fine, but it just seems to take about 1L less. Maybe I’ll have the oil sump dropped at some point to check if there is anything
