The engine light started flashing at me when I turned the key too on in my 32 gtst, wasn't like that last time I drove it. It stalls when I touch the accerator and struggles to start, I havnt driven since, only moved it from where it was parked, And holy shit it has no power to even move it, I did some research on how to check the ECU fault codes but didn't have any luck when doing so (i might possibly be retarded) im keen to get this sorted ASAP
Any help would be awesome as I'm ripping my hair out trying to figure this shit out myself >_<
I'll answer any questions as best I can...
Mods are:
Exhaust
Gtr FMI
Coil packs
Pod filter
r33 series 2 turbo and dump pipe
Running 10psi
Stock ECU, AFM etc
Its in limp home mode. Disconnect the afm and see if it runs better.
U need to try again to get the fault codes. They should tell u which sensor is farked
Where are u located?
Replaced the AFM, disconnected the battery for 10min, reconnected and still playing up, if I touch the throttle and gradually bring the revs up it doesn't misfire (much), but if I stomp the throttle it cuts out for a second then spits like a mofo, and shoots fuel out the exhaust.
I'm located on the gold coast..
dude i got the same problem with my stagea. ive been looking around on the net and i from what ive found so far, it could be AFM or the o2 sensor. im planning on replacing my o2 sensor tomorrow if i can find a shop that has one. im also on the gold coast so if i fix my problem, id be happy to help you with yours
Awesome :D, well ive ruled out the AFM itself (replaced with a new one) could still be the looming? And I replaced the o2 sensor about 6weeks ago with a second hand one from nizzpro, whether or not the o2 is gone again I'm not sure, Nizzpro stock brand new o2 sensors for $80 or second hand for $40. Let us know how you go, i just don't want to dump It into a mechanics hands just yet if its a small problem for them to charge me labour for unscrewing a couple things :/, could be a coil or igniter? Possibly an air leak? Under boost sucking air that doesn't go through the AFM? Or leaking air pressure? Really starting to niggle me haha
Another thing I noticed, after resetting the ECU, and simply turning the key to on (not starting the car) the engine light spazes out straight away so leaning more so towards an electrical issue..
  • 5 months later...
hey mate i have an issue similar to this,
i have same car, car runs fine in neutral and revs to about 5K than mild backfire, it was in a dudes yard for ages but ran fine got it nearly home and it started loosing power really bad!
now it does not have any power when in gear to move a meter forward or a meter back. it just looses revs and stalls when clutch is released, umm its pretty stock just a pod filter,
i ran 10 liters of high octane with injector cleaning fluid and it has not helped i thought it was possibly clogged injectors this did not work, i need help aye im pretty shit with cars
any help would be great!!
Cheers man.:cheers:
    • I'm seeing torque specs all over the place for the OUTER tie rod, but none for the INNER tie rod, where it connects to the steering rack. Even in videos, people are just tightening em up as much as they can with a wrench and that's it. Anything tightened down without torque makes me nervous. Anyone know what the spec is for it?
    • Hope you had a great time here in our tiny country.   The JDM scene we have here is quite small, it's mostly BMW, Volkswagen with burble tunes haha. But the few JDM cars we do have in the scene are pretty nice. Some of my friends drive cool s14's too. Both built engines, red one makes abt 500, blue one abt 400 i think?
    • Ye good idea , would have never thought of something like that. Might aswell do it to every pulley and the balancer while I’m there
    • Use an LS1 or similar, via kit like Frenchy's. But.... It's probably not the alternator. It sounds like belt squeal, which would be because the pulleys are glazed. Rub every groove on the pulleys with 120 grit paper. Report back. Oh, and new belts afterwards too. The old new ones will be shitted up already.
    • Hello all I have 2 r34 sedans , one turbo one na, only recently aquired the na 34.  Man what is with these things.... My turbo 34 started sounding like a super charger, it was screaming at anything above 4000rpm , I took the alternator apart and replaced the front bearing which is the only one I think you can access and it did not fix the issue so presumably the bearing in the rear of the alternator is gone. ( diagnosed it was the alternator by taking off the aux belts one by one to figure out which pulley or bearing it was )  My friend gave me one he had lying around, Installed it , it did not squeal for maybe 500kms and now its started to squeal again briefly on startup  Recently got an na r34 and I replaced the timing belt, water pump + all the auxillirary belts. Runs amazing but it suddenly developed the same squeaking problem but significantly worse, Ive had my neighbour come down screaming at me because it was waking her up everytime I moved the car. It takes a good 2 minutes before it quietens down.  Im yet to diagnose where its coming from but im fairly sure its coming from the alternator aswell. My question isnt about how to fix it but rather where can you get a new alternator for an rb25 neo??? Ive searched everywhere but I havent been able to find a direct fit oem type replacement thats not genuine. All the automotive stores sell an oex one - BXA035 - which I picked up for cheap through a friend with staff discount , got it home only to find the connector is completelty different.... As far as im aware bxa035 is for rb20/30's and after a bit of figuring out the bxa035 has an ev14 type connector, which is tiny compared to the rb25 connector. I actually had an ev14 connector lying around which I was considering just replacing the bigger plug with to get the alternator working but the bxa035 is rated for 70amp vs the rb25 alternators are 90amp ( or so ive been told ? ) That paired along with the fact im about to install an amp + sub in the back and I have the stock sized small battery Im not sure itll do the job unless anyone has another opinion?  I know and have seen all the websites selling the ls1 alternator conversion kit but I am not going down that route, nor do I have the money to. Hopefully I can figure out how to get 2 brand new alternators for both cars. I would buy second hand which there seems to be many of but considering how common this seems to be im sure If I installed a second hand one it would start squealing in no time  Or even better if anyone knows how to fix the issue directly with the alternator itself... Any input appreciated Thank you     Link for bxa035 connector picture
