Hey Guys thought id make a build thread of my R33 i bought a while ago. Ive always loved and owned silvia's. But one day a mate of mine at work mentioned how his mate was selling a skyline for dirt cheap. Anyway the buyer fell thought,to lazy to pick it up. So i went around and had a look at it It was a 1993 R33 GTS RB25DET manual series 1 coupe. When i sore it though it was in pretty bad shape it had been sitting in a shed down near Margaret River for the past 7 years. As you can imagine it had like an inch layer of dust all over it and inside it.Owner had hit a curb/pole and bent the front LHS suspension, dented the fender, damaged the door etc. and got a yellow sticker. It was just sitting there doing nothing going to waste only had 120,000 kms on it and was all original besides the exhaust and rims. So i knew it had plenty of life left once fixed up. Plus i can build it up from scratch to how i want it. Its going to be build to be a nice street car that i want to take drifting and maybe even do a few time attack events like the antilag ones. Anyways once the damage is fixed and registed the mods will start. ill try get plenty of pics up. Cheers
:D
https://www.sau.com.au/forums/topic/379954-brennos-r33-gts-t/
    • First up, I wouldn't use PID straight up for boost control. There's also other control techniques that can be implemented. And as I said, and you keep missing the point. It's not the ONE thing, it's the wrapping it up together with everything else in the one system that starts to unravel the problem. It's why there are people who can work in a certain field as a generalist, IE a IT person, and then there are specialists. IE, an SQL database specialist. Sure the IT person can build and run a database, and it'll work, however theyll likely never be as good as a specialist.   So, as said, it's not as simple as you're thinking. And yes, there's a limit to the number of everything's in MCUs, and they run out far to freaking fast when you're designing a complex system, which means you have to make compromises. Add to that, you'll have a limited team working on it, so fixing / tweaking some features means some features are a higher priority than others. Add to that, someone might fix a problem around a certain unrelated feature, and that change due to other complexities in the system design, can now cause a new, unforseen bug in something else.   The whole thing is, as said, sometimes split systems can work as good, and if not better. Plus when there's no need to spend $4k on an all in one solution, to meet the needs of a $200 system, maybe don't just spout off things others have said / you've read. There's a lot of misinformation on the internet, including in translated service manuals, and data sheets. Going and doing, so that you know, is better than stating something you read. Stating something that has been read, is about as useful as an engineering graduate, as all they know is what they've read. And trust me, nearly every engineering graduate is useless in the real world. And add to that, if you don't know this stuff, and just have an opinion, maybe accept what people with experience are telling you as information, and don't keep reciting the exact same thing over and over in response.
