Bought this F-Con iS from a someone on the 350z-tech forum and was planning to have it installed on my V35 skyline.
Have Since sold the car and bought an Evo X instead and so my modification plans have changed as the fuel maps of the stock Evo ECU can be tuned without the need of a piggy back.
As I've never installed it, can't verify how good this runs, but from visual appearance it looks in really good condition.
According to the HKS website, This piggy back is capable of correcting fuel and ignition timing, has built in FCD and SLD and also works with newer nissans with the NVCS control
Now the bad: one of loops on the metal mounting bracket is broken. As you can see from the detailed pictures the ECU housing itself is in no way affected and I'm sure it can be mounted securely with the existing 3 points.
Also you will need to purchase the harness for the vehicle that you plan to use it on.
I am selling the ECU only. You can contact your nearest HKS dealer and they should be able to get the harness without any problems
Edited by fcruz3r
https://www.sau.com.au/forums/topic/379956-hks-f-con-is-ecu/
