All items located in Cairns 4870, and are plus postage - express, registered, standard, whatever you want, to anywhere needed.
First up - brand new adjustable cam gear to suit RB engines. Steel outer ring for durability, aluminium inner. Came as a set of 2, I only used one on exhaust side. Has hi tensile bolts and washers already post-78602-0-87592900-1318460814_thumb.jpg
fitted, so good to go. Have used mine for about 5 months now and works a treat, set to the recommended 2 deg retard and good gain everywhere, quicker spool. $45 for this.
Next, brand new genuine SFS silicone top radiator hose. This was an extra they had put in by mistake when I bought my set, which is why there's no bottom hose as well. After $25 for it.
70mm ID SFS silicon joiner, 70mm aluminium joiner, 76mm aluminium joiner, 2 1/2>3 inch reducer (or increaser, whichever way u look at it). All brand new, although the reducer has been stored in the garage for quite a while through a few moves so is slightly scuffed. $5 each or $15 the lot.
as-new Turbosmart Kompact BOV, bolt on for Skylines. Used for less than a week (thought my stock one was leaking but turns out they're designed to lol). Prefer to keep a stock looking engine bay so have put old one back on. Paid $190 for it, with receipt available for warranty, original box and Turbosmart sticker ;). After $140.
post-78602-0-68148300-1318462221_thumb.jpg post-78602-0-00184700-1318462237_thumb.jpg
stock series 2 R33 coilpacks. 107,000k's on them, all working fine at time of removal, no misfires or issues. Changed for splitfires when I did recent major service. $40 the lot.
Check profile page for feedback from previous buyers, I value my reputation as a seller - feel free to PM me with any questions or offers on items listed :)
also have an R34 stock side mount intercooler with shroud. No damage, general minor scuffs from being on a car for last 10 years. Happy to post pics if needed. $80 for this + post.
Hey,
Interested in your cam gear, i like the idea of quicker spool. I've got a niztune ecu with a hyflo turbo, wonder if it would work??!!?!
If so how much for the postage to Brisbane?
Cheers
Simon
    • Throwing my spoon to the soup here a bit.  When I installed a 044 back in 2012, along with the direct power mod, the car became very difficult to start. To a point I burned one starter motor as I was late for work and tried to get the thing going. With some tuning and careful use of gas pedal when cranking it became bearable. Trying to make this short as possible, but the 044 died after 2-3 years, after which I went with an AEM 320lph pump, which also died after about 4 years to my dismay. After that I went with a Nismo pump, and while trying diagnose an emissions problem, I noticed for the first time that my fuel pressure was 5bar/72psi on idle, and that removing the vacuum line did nothing. After monitoring the situation, and removing the direct power feed and going back to FPCM in attempts to remedy it, I noticed there was fuel in the pressure regulator vac line. Kept the FPCM, installed AEM external regu and the car became sooo much better in every way, including starting. And I had driven it like it was for 11 years.. Anyway, I agree these are likely two different problems, and the FP problem you just haven't noticed before. I do not know much about haltecs, but what first came to mind was the CAS, which probably is not there any more. So how is the wiring from haltec to gauge cluster? How is the battery voltage and alternator?
    • Your car was auto before? You have different diff ratio (auto vs manual i think? or n/a and turbo?)
    • +1 for getting a screen off alibaba, CarPlay/Android Auto is vastly better than whatever navigation cars had 10 years ago. I got an Android screen for my 2015 BMW, huge difference. Fully compatible with factory stuff including iDrive controls.
    • Yeah, my offer was more to show exactly how rough and ready the rig can be and still be useful. Youtube vids will definitely show cleaner setups. Same concept though.
    • I would guess the seal has gone down at the speedo drive and gearbox oil has crept up the drive cable sheath and fouled the speedo head.
