hey guys, recently bought a motor off here and just seeing if anyone has any input on this as its doing my head in ! pretty much just a standard motor rb25/30 wise with twin throttle bodies. it cranked over (when at mechanics) and he bled the coolant and let it run for 30 minutes id say, then now it wont start. it kicks over but the thing wont fire, he said he tested it and hes getting no injector pulse, now ive checked power from the green wire going to injector loom (power) checked to the coil pack loom (power) even under the glovebox that thick pink wire (power) so i have no clue what to do next, im willing to play around with it but in about 2 weeks ill have to get it to an auto elec but i want to save as much cash as i can if i can. cheers guys the link is here.
Pull out the Crank angle sensor, leave it plugged in, turn the power on but don't crank it over.. spin the CAS and listen for the injectors ticking. if you can hear them then its not that if not try to test another CAS in the same way..
Edited by rsx84
ok so electrically everything is working, the cam timing was way off as ill show you in the picture, around 20 teeth too much. re-set it today and something still seems wrong, not only it wont start im thinking the cams may have been set wrong too because ive put everything back stuck it in 4th pushed it foreward and it doesnt run freeely, you can feel its grabbing hitting metal on metal on one or two cylinders, i plan on doing a compression test tomrorow to tripple check but i think the motors gone because of how far out it was, going to get it inspected this week hopefully...
Uh oh, would have bent valves,
From now on before u try and start the motor ALWAYS turn the engine over by hand(using a 27mm socket on a ratchet) that way if it hits the valves and pistons u will feel it and shouldnt do damage. Then u can fix cam timing and try again
unless you can hand crank it freely all the way around you are wasting your time with a compression test. the bolt holding the idler bearing in my 25 snapped it idle losing all power, engine turning over fine there and then again but once it cooled down the exhaust valves in #2 dropped onto the cylinder head. if it won't turn all the way around when hand cranking as per above, take of the exhaust or inlet manifold and feel around in the head you'll soon find the problem... who did the timing?? ie: was it like that when you bought it?
Also the pic really don't help to judge if it was out, line the dot on the inlet cam with the white line on the backing plate on the left on the pic (not the ones at the top) the dot on the exhaust cam should then line up with the other white mark on the backing plate (again not those marks on top) then check your harmonic balancer also shows TDC.. all dots and lines should meet..
Edited by rsx84
Ok the person that rebuilt the top end has marked it wrong and my local mechanic pretty much just swapped the rb30 with the 25/30... he put the markings back to how the engine builder had marked it which now i know is wrong, i did set it all back to factory, put the car in 4th and pushed it probably 3 or 4 full rotations, its still hitting, same as before except now when you try start it and you have your foot to the floor it backfires and you can hear the petrol igniting through the plenum. ive already organised a local skyline specialists to take a look at it and fix anything wrong with it, hopefully only a handfull of valves but will have to wait and see.
when you say hitting, do you mean its hitting but still fully cranking around or is it stopping when your cranking it?? stopping = bad, hitting = still bad i'm afraid. both really means the head comes off the block, replace a few valves and shes sweet.. just got all the parts in to start my full re-build so i know what a pain it is..
Edited by rsx84
    • It only looks tidy, as most of the stuff that was on the whole back wall, is now in the trailer to go to the tip, or has been shoved in my 2.2x2.4m "Spare parts room", and now I can't get to anything in there Ha ha ha I could definitely do with a bit more space, but I'd just end up with your problems I'm going to enclose the car port beside the garage, and move a lot of stuff into it I think. OR... It will be setup as a fabrication area, and the main garage will have parts storage in it. I'm not sure yet... Need some pictures of that big shed you've got with the bikes and Skyline in
    • No. I think it's gone. 😭 I think you can get body coloured ones on eBay so I think I'll get one of those... Or just hang a red ribbon from the hole and whack a TOW sticker next to it.
    • Can't say I've had a bad experience with one on my car, then again it only gets washed once or twice a year... The wheels on the other hand, get a good spray often due to my shitty dusty pads.
    • @MBS206 thats pretty neat and tidy to me!  I'll get a photo of mine when I'm out there next. It might require multiple photos to understand the scale of the atrocities though... In total I have 4 sheds of varying sizes and layouts. Main shed is 14x8, second shed is 3x8, third shed is 11x2.5, fourth shed is around 6x4.  All are pretty much full.   The main goal of my cleaning tsunami is to make the main shed predominantly car and motorbikes only. Second shed is my metal fab room (2 x bench grinders, drill press, bench belt sander, metal band saw, scrap metal storage and some of my garden tools.  3rd shed is more bigger garden stuff, storage for engine crane, jack stands, concrete grinder, concrete mixer, air compressor lives there, and it now has two 2mx2m pallet racking shelves with itemised boxes holding building stuff, electrical stuff, plumbing stuff, etc, etc.  The 4th shed is Ryobi electric ride on mower, mini boom sprayer, ancient Kubota tractor, more garden stuff!  I have got a lot of shit....  Then there's the pool house (8mx4m) and the pool pump shed (4mx4m).  I built all of the sheds over the 11 years we've been here.  The main shed was a Ranbuild kit, the rest are all custom made to fit the areas available. Building the main shed taught me a LOT as I had no idea about building anything prior to that!  I've still got one more in me. It will be my man cave which I poured the extra concrete for way back when I poured the concrete for the main shed. The idea is the Skyline will be a centre piece of the main cave once (if...) it's finished.  I told my now 14 year old son yesterday that I will 100% drive him to his year 10 formal in 2 years. Still a long way off but at least I now have a date to work towards! 🤣
    • Modern oils are amazing. Add tyres to that as well.
