Hi there,
So a few weeks ago on a bit of a drive my R33 GTS started running very sloppy, it was very gutless and almost sounded like i had a lumpy cam in it or something. Also the sound out of the exhaust was very poppy and i could smell petrol as i was driving.
It was coming up to a 200k service, thought it might have been a dirty/dodgy spark plug that might have been stopping a spark to a cylinder. Its pretty obvious that only 5 out of the 6 cylinders are working.
I got a service as soon as possible, changed the spark plugs etc. Took it for a drive with my mechanic around the block and nothing, it was running great. Later that day i went for a drive to the bank and it started doing it again. Just my luck.
Now this idle/running sloppy thing only starts after the car has been warmed up an about 10-15 mins of driving (which some people have thought of that to be unusual).
I recently showed a family member who is also a mechanic. He took a quick look over it and said if its not the spark plugs, it could either be coils, leads or injectors. He also gave it a rev in neutral and after a few revs, when it hit about 5.5-6k it did a big backfire.
I would like to know of anyone who has had the same problem as mine. I have looked around at other threads and others seems to have similar problems but the question never really gets answered i suppose.
Any help would be great.
Thanks
https://www.sau.com.au/forums/topic/380056-r33-gts-runningidleing-rough/
  • 4 weeks later...
I got this problem right now im going to try the o2 sensor tomorrow and see if it helps.worship.gif
Save your energy - it won't be the O2 sensor!
I reckon it's a coil breaking down. Work out which cylinder is running crook, then swap that cylinder's coil with another coil, see if the misfire follows the coil.
Blind Elk was right worship.gif ended up being my TPS.. although now that it idle great i have noticed it struggles to boost sometimes usually in 3rd gear weird ill go for a tune at Unigroup and see what they say.
good luck with your car
    • Solid update, got all the downforces now.  You going to be running aus time attack again? love the jacking solution, spend the dollars on what makes it go fast is best way.
    • Back in January, I noticed my car felt noticeably weak. I had the injectors cleaned, which seemed to solve the problem -- until now. Recently, the car suddenly lost power again while driving. Suspecting the injectors, I brought it to the mechanic. He recommended replacing them entirely, saying the current ones were getting unreliable and fiddly to work with. I could not find a direct replacement for my current injectors. The closest match I found were 440cc injectors. This led me to look into the possibility of upgrading -- and of course, that would mean remapping the ECU. From my research I found: The OEM Part numbers are 16600-72L20 and 16600-72L21 Both the RB20DE and RB20DET use the same 270cc injectors. There are much better options out there over the old OEM injectors. Nistune could be a viable tuning option. While the RB20DE isn’t explicitly listed on their site, the ECU is essentially the same as the GTS-T version - just with a different map. The ECU code on mine is listed as supported. One concern is finding a tuner who works with Nistune. Aftermarket ECU like Haltech and Link, but this would be the most expensive choice (and possibly overkill for a mostly stock RB20DE) I admit that I am very new to the tuning scene and would appreciate any insight or recommendations regarding this.   These are some SAU links where I got some of my information from for reference: https://www.sau.com.au/forums/topic/380324-rb20de-injectors/ https://www.sau.com.au/forums/topic/477396-factory-270cc-injectors/
    • The inspectors are not forensic by any means but if you forge your documents and/or badgings on vehicle parts and are found out, the consequences are just far bigger than if you just run illegal parts. And their job quite literally is to cross reference what parts you got installed and what your papers say you got. Something as silly as your suspension being 1mm too low will fail you. Nonetheless I asked if someone knew the damn pipe and I certainly did not ask for smartassery or underhanded comments, no idea why you need to be told this. Great way to waste both our time.
    • As useful as you explaining what forgery is... But then again, I wasn't aware your inspectors were also forensic experts and inspect nameplates on each component to confirm everything is original. They must inspect roughly 3 cars a year at that rate. You're right though, my comment doesn't help you in anyway, so I'll go talk to my wall now. Cheers.
    • Say that to the guy that is going to fail your inspection or tow your car for illegal exhaust modifications. If you have anything else useful to say, please go tell your wall.
