ok may be a dumb n00b query but here goes...
when i take my car (95 NA R33) to the redline in 1st gear it starts 'coughing' until i change into 2nd and then at the redline in 2nd till i hit 3rd..
its sort of like a misfire but without the sudden lurching juddering loss of power.
would there be a limiter on the car? or could it be a fuel issue? or could i just be a really crap driver :)
the car is standard apart from an aftermarket exhaust.
https://www.sau.com.au/forums/topic/38008-my-r33-has-a-cold/
your speedo is getting less accurate as you go faster. Considering 10% accuracy allowance as per ADR rule, a ground speed of 180km/h where your speed limiter kicks in may be shown as 180km/h plus or minus 18km/h... so can be somewhere from 162km/h to 198km/h on your speedo (+/-2cm past ur 180 mark). Speedo also get less accurate as car is older, sometimes by as much as 10k at only 60km/h!
ask a copper to double check your ground speed with his radar, then you'll probably find out for sure :D
https://www.sau.com.au/forums/topic/38008-my-r33-has-a-cold/#findComment-767616
not all speed limiters limit you to 180klms, in a WRX it's 205 for an auto 210klms for a manual.
So it wouldn't suprise me if you could get up to 220-230klms before it limits the speed, you'll crap your self when it happens the first time.
As it feels like your've just totally f**ked your engine, real bad.
That's also saying you still have the speed limiter or it's turned on.
https://www.sau.com.au/forums/topic/38008-my-r33-has-a-cold/#findComment-768080
Hey asylum,
It does sound like the rev limiter, mine makes the cold sounding noise (even tho my friend thinks its a sweet noise) when it hits redline. :)
But if you are not sure.. take it to your mechanic and ask him.. I'm sure if he is a good/nice mechanic he wont charge you for this. :rofl: Or alternatively try to drag a car knowledgable friend next time and ask him when it happens again.
https://www.sau.com.au/forums/topic/38008-my-r33-has-a-cold/#findComment-768780
Hey asylum,
But if you are not sure.. take it to your mechanic and ask him.. I'm sure if he is a good/nice mechanic he wont charge you for this. :D  Or alternatively try to drag a car knowledgable friend next time and ask him when it happens again.
yeh i like the sound too but i don't wanna kill my engine hehe
cheers guys :rofl:
https://www.sau.com.au/forums/topic/38008-my-r33-has-a-cold/#findComment-768982
    • Yeah I suspect even if you hold airmass per cycle/cylinder constant if you get too far away from stock you're still going to have problems running the factory tune within the bounds of the factory load scale. Cams, different displacement/rod ratio, etc. I'm just lucky that the GTIII-SS with wastegate boost + CA compliance cats is pretty much equivalent to stock turbos. When I have actual space I can finally get it tuned and modify the fuel system for flex fuel to 100% handle any detonation concerns when cranking the boost to whatever those dinky turbos can put out.
    • I would say no, why, because my daughter, who also lives in Goulburn, hasn't recommended us going there Pity, as we miss all the German joints around in Sydney, actually, the restaurants are the only thing I really miss about Sydney, and a special mention to Ishibanboshi at Bondi Junction, their Kara-age Don is heart cloggingly deliciousness (always added a special boiled egg...or 2) 😋
    • Does that German restaurant still exist in the old place out the NW end of Goulburn? When I say "out the NW end of"...I am really being vague. It was 1997 when I was last there, and the only point of reference I can recall is that it was on the opposite side of the main drag from the big merino. And when I say "opposite side of the main drag", I don't mean "on the main drag". It was either a couple of streets back from there, or might have even been out in the sticks a bit further. Was an old farm building or mill or somesuch. And when I say "the big merino" I might actually be thinking of a completely different part of town, because I just looked on maps and the big bugger is not where I remembered him to be! The food was good, consisting largely of various German mystery-meat sausage/loaf things and kartofflen.
    • So while the second sentence is completely correct and the whole point of the conversation, the first sentence bears consideration. If this bloke is just hoping to throw big turbos on and drive it around, because there are no helpful facilities at all in his tropical paradise** then he likely has zero chance of even knowing what the TP is on the last column in the stock maps, let alone know whether the ECU is operating anywhere near it or past it. So the point is very very moot. And, per what I said before, at stock boost on those turbos, you may well be off the end of the map. **I'm just back from Vanuatu, so I know exactly what small Pacific nations can be like wrt paradise without requisite facilities. But it's not even that simple. I put a high flow on my car and had to drive it around without a proper tune because of the lack of opportunity*** to put the bigger AFM and injectors into it to allow it to be tuned. I had to turn the boost down to less than I had before, and back off the boost controller's ramp, because it was exploring parts of the map that it didn't drive in before, and really couldn't access for tuning on the dyno either, and so was pinging. It was still well within the last column, because when I first**** set up the Nistune on the Neo I rescaled all axes of the maps to give some more space to explore. ***Family dyno was broken ****This was 13 years ago, and the TIM thing wasn't a thing then and so TP would definitely grow when pushing past the stock tune's limits.
    • Yep, this bit another local owner. I caught it before putting the transmission back into the car, what I noticed was the pressure plate fingers weren't flat and even. It's more obvious with the pull style clutch because the throwout bearing ring was visibly not flat once everything is put together. Nismo should really update their instructions to call out this specific detail. I'm not even sure the clutch as-shipped orients everything properly.
