Tried searching around but didn't come up with any R34 info, heaps of 32/33 but minimal solid details on the 34 gearbox.
So basically I'm trying to work out what sort of power these boxes can handle reliably.
Ideally people with first hand knowledge running x amount of power with no issues, versus accounts of people breaking them at x power.
I know that a lot of it can come down to treatment/servicing but looking to get the generally accepted 'she won't hold for long' levels.
k go!
https://www.sau.com.au/forums/topic/380109-34-gtr-gearbox-limitations/
Its not power that breaks the getrag most of the time. Like all gearbox breakages it is mostly shock loading.
The R34 getrag is basically the same as a supra getrag box with the exception of the AWD transfer case. They run them at over 1000hp in the supra's. But if you've ever been in a supra, most don't get traction at all a well when they are over 500hp atw.
In the GTR however the AWD causes more load on the gearbox output, so the gearbox is more likely to sustain damage from launches. The generally accepted maximum would be around 600hp atw, but the quality of your tyres and the surface your driving on are the real deciding factors.
There are quite a few 1000hp R34's around that still use the standard getrag, however most won't have tried to put that power to the ground through a set of slicks on a drag strip surface. The yellow R34 (Nitto), the powertune white R34 (GTRB28) and the blue envy dyno (jetters edge) cars are 3 that are quite publicly know of as having serious power while retaining stock drivelines for at least part of their lives. The powertune car aparently has a sequential box now.
I do know of someone that has broken an R34 box through just excessive power, not shockloading. I can't remember the exact details, however it was either 5th or 6th that was broken, and it was at high RPM with an extremely healthy rb26 making around 850-900HP. The RIPS built R33 GTR called "BORG" (build on GTROC UK Forum), broke a PPG gearset equipped getrag the first time they drag raced the car as well. I believe that was on slicks with around 800-900 hp as well.
You can toughen up the getrag with billet intermediate housings around the gearsets to reduce the twisting effect that driveline torque is having on the box. This keeps the gears meshing properly and stops the housing breaking. I have also seen a getrag that used a chromoly thrust plate on the end of the intermediate housing, which helped reduce distortion of the gearbox where thrust was normally absorbed by the alloy housing of the box. A PPG gearset helps, but straight cut gearing sets also take away from the streetability of the car unless you like that sound. To go further you start to venture into no so well charted territory, and need a real transmission pro that is able to further improve the lubrication of the box which usually means custom gear modifications, oil squirters, external fluid pump and cooler. The costs to do this get pretty extreme and put you into hollinger territory which is where most of the insane power level cars seem to end up.
The only other option would be an auto transmission with an AWD transfer case fitted, as per that black R32 gtr with the RIPS engines owned by someone on the forum here. I can't remember their username though.
  • Like 3
  • 4 years later...
My info is not worth much as I do not race or  drag but run it through the hills and have a bit of straight line fun with it. I would think if you are going hard all of the time and trying to go quicker , even with my 618AWHP and a lot of torque could cause some problems but as GTRNUR said, there are some real beasts running 800 to 1000HP :devil:
 Mine is 461KW , 1000Nm around 4000rpm. Getrag 6, twin coppermix C spec, quaif front diff, trannie has a few more plates, a Nismo2-way lsd and 265x35 AD08Rs. So it spreads the load to all wheels and puts a lot of twist on the box, only spins wheels a bit if it is a freezing morning. I stopped dropping the clutch but when I did I loaded it first.
Has handled it well, except I nearly fried the clutch being a DH the other day, but after the smoke drifted off, OK again,  lol
Thanks for the reply.
I think we have similar set ups :)
I'm also running nismo 2way lsd's
Another thing that was appealing is I have a 33 GTR so running this box would make it ridiculously responsive with the 4:11 gears - it already is very responsive :)
i know the JEM 34 GTR was running this box with 1000hp for some time before upgrading to a ppg sequential.
Ill keep researching. The OS seq was an option however I cbf pulling the box out every 6000kms to change dog rings
Hi Daz
I change gears now when it was just starting to go before , lol
Great street setup :D
Piggaz put the OS seq in his 33 and said it is mad , wait until that one is finished, it will fly, if only I live that long, lol
  • Like 1
  • 3 years later...
I think my r33 GTR gearbox is ending cuz i can hear grinding sometimes on gears 4 and 3 ;/
I have a chance to buy gearbox from r34 GTR and do the conversion. Is this worth the money to do this?
The complete swap with the gearbox will cost around 10k euro and the used gearbox from r33 gtr can buy for around 1.5k euro
I heard that this r34 gtr gearboxes are stronger from r33 and r32. Is this true or not worth the money?
Major thread bump.
Rebuilding a Nissan 5 speed is not that expensive, you will save money vs a 6 speed conversion. Keep in mind if you want to have proper gear ratio spread you need to convert to a Nismo 3.9 final drive on the differentials, otherwise the gearing is excessively short for a street car.
If you have a lot of money to blow on making the perfect street car then sure, a 6 speed Getrag conversion with either 3.7 or 3.9 final drive on the front and rear diffs would make the best of the fairly laggy RB26. But if budget is a concern then I would just rebuild the 5 speed and try my best to widen the powerband of the RB first.
    • The easiest option might be to just spray a bunch of fish oil in there.  At least that way you can feel like you've done something while you continue to ignore it
    • I'm firmly on the "zero compliance is good compliance" for FUCAs. I'd be looking to solid metal joints even if the primary reason for having them is because they facilitate the twist in the arm. I have never been more happy with the way the front suspension behaves than I have since I got rid of the FUCA bushes. Even the thin little (short lived) poly bushes in the Whiteline adjustables have too much compliance for my liking. It probably won't be long before I have sphericals nearly everywhere, probably including both top and bottom arms in the rear, and I'll start complaining about the increased costs for dental work. But I will be enjoying the driving more, I'm sure.
    • Plus, you'll get great experience in bedding in pads!
    • I have offset Nismo brackets so the fact the gktechs can pivot is less important to me. I have 170mm JIC arms with bushings - but they provide no adjustment and I'm not sure whiteline eccentric bushings will fit them (I don't want to ruin the bushings currently in them to find out). Ideally I want something with bushings + adjustment; hence why I'd like to find a pair of these. Unfortunately they aren't easy to find.
    • @Vee37 How much do you really care about finding these pads again? If your pads are quiet, work well and produce minimal dust, really isn't that enough? If you are set on finding the exact pads again, I suppose I'd do something like this -  Visit your local Jax, find out what brand of pads they carry. If the Jax workshop you previously went to had the pads on the shelf, then you can almost guarantee it will be of said brand.   I'm guessing you don't have the receipt for the previous work and pads. Can you visit a Jax workshop and see if they can look up your previous job to see what pads were fitted?  Still no luck? Put your stalker hat on, find the staff that used to work at the Jax store and ask them. Talk to local workshops, try to find out where the mechanics went to. Talk to Jax workshops, maybe they relocated to another workshop. When it comes to mechanics, its a small world. You'd be surprised how easy it is to track someone down. If these ideas don't work, shit will start getting crazy very quickly.... You could find out every brand and model of pad that fits that car... and try them individually ticking each off the list if it wasn't the one you were looking for.... If you go down this path your going to want to learn how to swap pads yourself, it is very easy, takes minimal tools and space. If you have room to park the car you have room to swap the pads. Plus you have the advantage of making sure all the brake hardware goes back in so they won't squeal!
