Hello everyone,
just a pondering question, is it possible to make 32r running 4wd all the time without using the current electronic control system. In other word I want to cancel all sensors and ecu and make it run awd permanently without headache .
Is it possible to cancel actuator from gear box and weld nut to press on clutches or keep then in engaged position all the time.
https://www.sau.com.au/forums/topic/380133-how-to-make-32gtr-run-awd-directly/
The pump unit isn't deisgned for continuous duty, but you mentioned getting rid of all that.
The transfer case clutch pack setup, if locked permanently would either:
suffer from 'wind up', if used on tarmac, as there can be slight differences in driveline rotation front to rear, and that will break stuff.
you will have mad understeer due to the constant locked 4wd mode!!!
The only way to do it properly would be to change the transfer case to a center diff arrangement as used in the subaru's and evo lancers....
Yes you can do it, no it's not a wise move. Not only will you reduce the hp driven to the wheels to give you acceleration, but you will destroy the transfer case from binding the clutchpacks too much
This + the BSM GTR tore the front diff off the sump running 50-50 4wd
they did find they were quicker on the track though (IIRC)
Locking the transfer is no drama, BSM did it with a solid transfer. I also did a similar thing with a machined shaft.
However both cars I know ended up with front diffs sprawled all over the circuit.
The speed gains were negligible. We found the only gain was in top speeds reached on the straights as exit acceleration was slightly faster. Entry and mid corner speed was actually slightly slower.
    • No. The ECU's hose is for a connetcion between the plenum (assuming single throttle body, not ITBs) and the ECU's internal MAP sensor. This is the primary load measurement of the ECU - so you need to get this one right. This has NOTHING to do with the boost contol. The wastegate also needs to see a boost signal - but it is actually far better for it NOT TO COME FROM THE PLENUM (again, assuming single TB, and not ITBs). This should come from the turbo's compressor housing (assuming there is a nipple on there, which there might well not be), or on the boost pipe somewhere between the turbo and the TB. On the pipe from the turbo to the intercooler is usually most convenient. The boost controller is then located between that boost source and the wastegate, ACCORDING TO THE CORRECT PLUMBING DRAWING FOR THAT BOOST CONTROLLER. There is no general diagram or instruction that will be correct for every case. Then the other ports on the plenum are for purposes such as Duncan described. If the boost controller has an internal MAP sensor, for a boost display, etc, then it will want to be hooked up there, alongside the ECU and the FPR.
    • Ok gotcha, so one post to fpr  another to bov  and I have the mishimoto boost controller and a link g4+ so I’d just have the tuner set it up properly. For the last two from plenum post throttle to  ecu/ boost controller, I know that I have a hose coming from the ecu that I was confused about so I assume that’s what connect to the boost controller from the ecu? And then the last is just from plenum to boost controller then to wastegate?
    • From there, it was just a quick electrical check, prime the oil and start her up Which, is not what happened. 1. Bloody seppo Aeropro battery holder. Not only was it too tall for the battery (which I'll forgive them for, I have another battery the same nominal size that is taller than Neil's one, but the bracket is a fixed height so the battery was spaced up) But the thing that really shits me is the hardware to hold it on requires a 7/32 Hex key. WTF. No-one will ever be able to remove or install the damn thing without a hex key they don't own 2. Kill switch no longer worked once the console was installed. Neil mentioned above he had to adjust the length but it no longer cleared the console once installed. Sorted. 3. Suspiciously, the brake light holders were hanging in the boot with no globes. Sure enough the stopper on the brake pedal was missing so they are always on unless the kill switch is activated. Will pick one up tomorrow (turns out 32 and 33 don't use the same stopper) 4. All that sorted, I turned on the kill switch, turned the key to ACC. Nothing. Turned it to IGN. Nothing. Checked some fuses and found the main IGN in the boot was missing which improved things once it was replaced. Now ECU and dash lights turn on with IGN but still no fuel pump. 5. Turned it to Start....ECU on, no fuel pump, no starter. Plus the voltage dropped straight to 9v.  I suspect the starter is f**ked but am going to have to work through it all and see what is happening, really looks like more than one issue. Does anyone have the R33 fuse box key with the circuit it sources from (eg BAT, ACC, IGN, SRT etc) and supplies? I can find a translated list showing Amps and circuit without supply circuit, and I can find supply circuit without Amps and target circuit.
    • 3rd time lucky, the AAC is now all plumbed up after getting some final fittings All set up under the plenum of maximum access
