First of all when i installed it Everything is fine but the idle sits at 1.5 When my old cluster was in there it was sitting at 1G. So what i did was swap the motor on the back of the rev taco and replaced it with my old one , So now its sits at 900 at idle i mean its closer then 1.5 But anyways i just noticed the rev taco is really slow i mean i put my foot down and it lags its not responsive at ALL Id push the throttle and it sounds like it reaches 5k-rpm and drops but because its so slow it doesnt even reach 5k it gets to 3k and by that time the rev is already back to idle so it makes its way back down again. FYI my speedo cable has snapped recently as well i dont know if that will make it lag so much! IM SO FRUSTRATED I spent 350 on this cluster i dont want to throw it in the f*kN BIN ARGHHHHHHHHHH!!!!!!!!!! what shall i do???
The reason i swapped it in the first place is because the nismo taco used to read 1.5k when it was really 1000-1100 and when i played with the rev counter it used to be floppy as in when i lifter the needle to 3k or whatever the needle would just drop back free fall instead of slowly go down. my oem taco didnt do that used to drop down slowly. maybe i didnt push the needle backin right?
I had exactly the same problem,
Here is the fix:
firstly I would put the nismo motor on the tacho back on then:
you need to take note of the idle with your standard dash, then pull the face off and back ( from memory ) so you can get to the back of the tacho inside the dash, there is a small calibration screw on the side of it, just adjust to match old one thumbsup.gif
make sure you have very clean hands and don't leave dust and stuff inside the dash.. cotton gloves if you have them to stop finger marks, I just made sure I didn't touch the inside screen.
If its just a tacho issue that should fix it.
Edited by tricstar
I remember seeing that screw how the hell can you adjust it while its idling? anyways i think I fixed it, OMG its so fiddly, anyways it seems like the needle itself was not pushed in properly and was the reason its slow cause it was getting stuck at certain points.
Anyways when you put the needle back on the face how the hell do you know what position your meant to push it in, I actually had the car started and i pulled the needle off and pushed it back on at the right position. It was like Trial and error until i got it in the right position...
Anyways at the moment my idle taco shows 1000-1100, My power FC shows 980-1000-rpm... Is this normal?? Anyways im thinking of pulling the face off again and matching it to exactly what the power fc shows? Is that more correct then the actual taco itself?
    • Well, in 2007 he must have been charging about $1800 an hour. He only looked at the car for 5 minutes. And another 4 to write the report wrong, and another minute to correct it. Mind you, this was for a car that was: Stock engine, fmic (hole in drivers guard), all alloy intake and custom air box, 3 inch turbo back exhaust, lowered, and a set of 17" Advans (255/40/17 rear and 235/45/17 front). It was nothing crazy. The blue slipper wanted the "hole in the guard" engineered. But that was because he got the shits that I wouldn't "relocate the battery from the boot, back to the factory position in the engine bay"... In an R33 GTST...     Also for emissions, E85, and don't go wild on timing. It's amazing how the closer you get ignition timing towards max torque, the last couple of degrees really throw NOx counts right up. And for the huge increase in emissions, it's only a small increase in torque.
    • He'll be looking down and swearing about "the damn apprentice" for trying to convince Duncan to use percussive maintenance... 😛
    • I swear at my GKTech ones every time I have to take them apart and replace a spherical. But I wouldn't swap them for anything else. They absolutely slay every other option, at least in terms of how they actually work. You sure you don't want to live with bearings? I mean, they don't have "ball bearings". They are rod ends and sphericals throughout. Tough as nuts, even though I have found more than one way to wear them out.
    • From when I was looking at getting the 86 engineered for the turbo, the joint said to put in a few euro 5 or 6 cats, then tune the car on a nice clean E85 tune When I was looking at a turbo for the MX5, it was basically the same thing, a couple of cats and a nice clean tune Although, it will depend on the year of the Jeep IRT emmisions standards required, and what mods are done, especially if it has a newer engine installed that requires a higher Euro
    • Yeah - but it's not actually that easy. There are limits for HC, CO, NOx and particulates. Particulates shouldn't be a concern in any petrol engine unless trying to comply to the very latest Euro standard. But getting a tune right so that all the others stay within limits AT THE SAME TIME is not a trivial exercise. You couldn't possibly get it right by just guessing at the tuner's dyno, unless he had a 4 gas analyser up the pipe, which is not often the case these days. It used to be. Every decent shop that did "tune ups" (as opposed to tuning) would have a 4 gas analsyer. Perhaps there's still quite a few of them around these days. But most "tuners" are only watching O2 and power readings.
