For anyone reading this and also to the original poster, speak to Chris from Audio Express. They can fit a decent quality TK104 GPS Tracker.
They aren't expensive and you will be able to find the car even up to 60 days after the car has had its battery removed. You can ever send an SMS to the device to tell it to shut off the fuel pump, sound horn, lock/unlock doors all via sms.
Welp, I might be the luckiest guy alive. The police have recovered the car and it is on its way to Chris at audio express today to get sorted...I really hope they catch the prick, aparently they have a good idea of who and its for more then just my car. Although I havent seen it yet so I have no idea what shape its in the police said it looked to be in good shape. I just hope the parts I picked up last week are still in the boot
thanks to all the well wishers
Get info so we can organise a special thank you to them for assisting with the returning of your car. :thumbsup:
dan,
yet to check if its at the shop or not.(he rang me this morning and I told him to send the towie my way and drop the key off to it.
I will look at it tomorrow.
this car will also be used for the tech night on security as it will show the people there how the thing was stolen.
I will call you tomorrow re tracker - there is a fair bit more to it than that.
good. once I and through with it your should be able to locate it VERY easily.
will talk more once I have stripped it down.
dan,
Tech night?
Link me
I pity the idiot that tries to take this car..
10 layers of security and 6 of those are VERY transparent and REMOTELY controlled.
those that were at the tech night will have some inkling of what I am getting at.
definitely a rave..
last thing a thief wants is attention - they will CERTAINLY get that.
dan kent,
about to send you a few useful images - call me when you get them.
    • Hi guys, I’m new to the GTR scene. Picked up an R33 GTR earlier this year that needs a lot of love. I’ve been going through the hot side, changing all the gaskets and while it was all off I managed to score a set of -9s. It still had the stock ceramics so I was pretty happy to get the 2860s.  I live in a small country in the pacific with 0 performance car scene. No dyno’s no performance parts, let alone stock parts for a skyline. I order everything from Australia and do it myself. This means I’ll be running the stock ECU. Maybe down the track I’ll get an aftermarket set up and do a remote tune.  Will the car run -9s on stock tune safely?  I have a very heavy foot so I really hope so 😂   thanks guys
    • perfect, no rush to address the leaking bush then, it's not doing much/anything
    • I'm not sure if it will bolt up, but.... I'm reasonably sure that the ID of the runners is somewhat smaller on the NAs. So it probably wouldn't be a good match at the flange where the top and bottom meet. So that would be a reason to not do it. And the skinny runners would be the bit you're keeping, which would be a reason to no do it. You'd want the big runners if you were doing any work to swap stuff. Why not just use what you've got, like nearly everyone else who has +T'd an NA? You don't need or want the TCS throttle or other stuff that is specifically DET inlet/crossover.
    • lol already been put in temporarily 3 years ago
    • Makes sense. For actuators, if the pressure itself isn't adjustable, that would mean I'd need to think about 2 different actuators with 2 different pressures on paper in order for them to work at the same time if the turbos behave differently. So measure the difference in psi needed to move both, and then get an actuator to match that difference. Assuming I cant get rid of it by adjusting the arms.  You're exactly right, never happens in gear 1 or 2. I can occasionally get it in gear 3 if going uphill but its very small. Only ever in 4 and 5. Seems kind of backwards that one of the points of VCAM is faster spool but if it introduces shuffle then it actually slows spool down.
