Last round for the year.
Championship will be coming down to the line:
http://www.sauvic.com.au/motorsport/2011_ClubChampionship.xls
See you all there!
Entry
https://secure1.ilisys.com.au/wrxc/motorsports_two/MotorsportsEntrytemp.php
Sub Regs
https://secure1.ilisys.com.au/wrxc/motorsports_two/Current_Supp_Regs.pdf
Entry List:
http://www.wrx.com.au/forum/viewtopic.php?f=23&t=71840&sid=a3f8b47012f5c17b2b27ddf9a528012e
Requirements
CAMS L2S/AASA
CAMS club membership with current date (SAU VIC Membership)
Fire Extinguisher
Two bonnet latching mechs (the standard double latch is ok, but for older cars with the single latch no good you need a second with a tie down strap)
Blue battery triangle 150mm x 150mm x 150mm (get yourself some blue contact from the news agency and cut one up!)
See you there.
2011 SAU VIC Motorsport Championship proudly sponsored by:
  • Replies 91
*yes I know you can't run the circuit, but you can stop, slow down and go straight back out for another run. 3-4 runs in a row will make for a much better day. SAU 2012 :P
How is HH for spectators?
Worth coming along with a camera?
Thinking of coming down for the day to check it out, since I've got plans to be about 30km south of there for a birthday at 6pm :P
Ye its not too bad for spectators. You miss some of the back sections regardless of where you stand.
Just means you see different parts, but there are a few vantage points to check out from over a few sessions to get a pretty reasonably look.
If you are in the area most certainly head past :)
I would say spectator access it just as good as Winton, if not better as you are closer and above the track.
The have a large pavilion with food and new bathrooms.
It is an extremely picaresque place.
http://www.skylinesaustralia.com/forums/index.php?app=core&module=attach&section=attach&attach_rel_module=post&attach_id=325919
Guest
    • What could be causing my clutch problem besides a bad master or slave then? Both those parts are new
    • Just came across this, but in QLD I start leave again in 2 weeks, if it is still available I might drive up and check it out Unless, @MBS206 do you live near here????, if so I could hit you up with a finders fee https://www.gumtree.com.au/s-ad/hope-island/auto-body-parts/nc-mx5-factory-hard-top/1328976391
    • My hold point for future mods is that I want a OEM detachable hard top first, but, finding one is a pain, MX5 Mania are looking for one for me, but, as hens teeth are more common, finding one in Australia is proving problematic  I can get a OEM one from overseas, hell, you can still get new ones in 'Merica, but, shipping is a absolute killer and I cannot justify the cost, or the risk of it being damaged during transport As for the aftermarket hardtops, whilst they do the job of being a hard top, and are fine for a track car, they don't seal well (read: leak like a sieve in the rain), and you need a plastic/poly rear window, plus they are a bolt in option only and not made to be easily removed I liked how the hard top on my NB could be fitted, and removed, by myself, in less than 5 minutes I know it sounds bad, but I'm waiting for someone to write off a car with one so I can swoop in on their pain, it will go to a good home though, so my guilt of this is tempered
    • I’ve got one on mine and it’s fine,
    • No, you don't want to plug the vacuum line, as that will turn that side of the booster into an air spring and probably make it feel worse. I'm not saying that the GTR master itself doesn't need a booster. I haven't paid attention to the GTR one to know what size it is cf the non-GTR ones. But when you think about it - they have to do the same job, which is to move a little slave piston a few mm to do what it is supposed to do, and that final action is the same on all the cars. So, it is very unlikely that the GTR MC is any different than the others, because it has the same pedal stroke and the same output requirement. The booster just makes it feel easier. I'd suggest you probably have an actual hydraulic problem. It's totally common on these old shitboxes.
