Ive got offered a pretty awesome deal for these rims new.
Just been reading about them and ive heard good and bad stories about them, the owners of them say there good but peoples friends uncles parrots brothers crack after going over road works and stuff.
Whats the quality of these and whats everyone 2 cents about them???
A Pro is apparently they weigh like 8kgs o.O
the wheels will be used for daily use, long trips, some track work and some skid pad work. so has to be sturdy. although atm my GTT is only about 180 rwkw.
Im thinking these or drift teks, is there anything else that looks similar that people think id like???
any input will be greatly appreciated but please dont over or under exaggerate, this is my wallet after all :P
thanks guys,
Jarrad.
https://www.sau.com.au/forums/topic/380213-rota-p45r/
from the friends uncles parrots brother it was less then a year and they were cracking though hah.
hence why i started this post. just seeing what everyone else thinks :)
thanks for your input guys! keep it coming!
https://www.sau.com.au/forums/topic/380213-rota-p45r/#findComment-6063228
Been running 18x9.5 P45R's on the GTR for about 18 months now with no issues, and really why would there be issues.
I don't drive into kerbs, I dont go offroad, I don't drive through roadworks and potholes - So basically I drive like a normal person and not like a "P plater drift champion".
Wheels don't just crack by themselves, abuse generally does it.
https://www.sau.com.au/forums/topic/380213-rota-p45r/#findComment-6063306
Yeah not to keen on dish. That's why I like the other ones :D
Think 18 8.5 +25 would fit a gtt good right round??
Don't want to roll guards so 9.5 is out
Yeah Thats right smithy. I found it hard to believe they'd just break lol.
https://www.sau.com.au/forums/topic/380213-rota-p45r/#findComment-6063432
wow that looks horrible imo just put my drift teks on same size and offsets as sunny's only gold/bronze ill hopefully be able to take some photo's at some point when it stops raining here. needa adjust coilovers now tho lol, i don't like the flat faced ones. btw my rears are 9.5" +34 and they sit pretty well
https://www.sau.com.au/forums/topic/380213-rota-p45r/#findComment-6065737
http://www.skylinesaustralia.com/forums/topic/146573-r34splease/page__view__findpost__p__5965040
there a link to my 34. drifteks 8.5 +34 front and 9.5 +34 on the rear. 8.5 on the driftek will be concaved but on the rotas they will be flat faced. if you are getting rotas you will need a 9.5 +20(ish)
https://www.sau.com.au/forums/topic/380213-rota-p45r/#findComment-6066289
Hmm looks pretty nice. Well ive been offered p45rs in any size in 18s I want for 1200. 1100 for 17s delivered so can't really pass it up, and I want the same size right round so I can rotate Tyres. So what should I do?? I've been told the 17s by 9 will fit my car heaps better but I want 18s. Do you think the concave is worth getting 17s for?? Personally I don't know or care to much about flat or concave, but do they look shit in the eyes of a wheel whore?? Hah.
https://www.sau.com.au/forums/topic/380213-rota-p45r/#findComment-6066450
get 18x9.5 +20 for all your rims with 235 tyres
https://www.sau.com.au/forums/topic/380213-rota-p45r/#findComment-6069525
    • Ok I get you. But isn’t the butterfly intake a headache with the +T?  see this is my plan so far but please advise me into the right direction.  Nistune Ecu, 1000cc Bosch injectors, TD05 or TD06 Kinugawa turbo using stock rb25det exhuast manifold, walbro fuel pump unsure of model I think it’s 450/460, spitfire coils and sparks to suit and a R35 MAF sensor and boost sensor.    I was thinking maybe do a cheap eBay plenum $400-500 or try find a stock det neo intake. I think I’d port match it so it’s getting the full capacity but open to advice please.  Thanks
    • The issue now is the 'fuel cut' while driving, and when it happend, it does not stall. This, I did not test the fuel pressure while driving as I cannot with a fuel pressure gauge. I do have Nistune logs, yes. I have also replaced the MAF Sensor.   Also related to the FPG Fuel Hanger – I just realized that I need a Deutsch Crimp Tool to crimp some cables for the FPG Fuel Hanger. Need to purchase additional cables as the kit only included 2, which are for the float. FPG has not responded to my emails so far since purchasing. I thought about taking it to someone and having it done professionally, but I am reluctant since everyone I took it to messed up in some way.
    • There's a good German place in Brisbane if youre up for the drive 😛
    • The German place in Cabramatta was rock solid, fresh pretzel cooked to order back then. Then it went all quiet, after all the poker machines were removed, then I believe it closed for good. I did drive past the other week and noticed outdoor lighting a big screen, but no idea what is there now.
    • Yeah I suspect even if you hold airmass per cycle/cylinder constant if you get too far away from stock you're still going to have problems running the factory tune within the bounds of the factory load scale. Cams, different displacement/rod ratio, etc. I'm just lucky that the GTIII-SS with wastegate boost + CA compliance cats is pretty much equivalent to stock turbos. When I have actual space I can finally get it tuned and modify the fuel system for flex fuel to 100% handle any detonation concerns when cranking the boost to whatever those dinky turbos can put out.
