Hey man,
I run the Rota Grid on my Gtr. (look at my posts if you wanna see pics)
Admitadly its a gtr so has a load more clearance, im running 18X10 265 with offset +15.
In the Rotas you want the concave!! they look gay flat face.
Minor Lip roll and u can do 9, 9.5's with nice offset. well worth it for good stance and nice wheels.
JD
found out today i can get the concave with 17 9 +25
what does everyone think?? 17s crap?? 9" to wide??
i think itll poke out of my guards by a cm or two.
if i slightly stretch some 235s will this hit my guards??
why is finding wheels so hard >.<!!!
thanks mate, just got offered the 18 8.5 +30 in an xxr 552
not to bad, think itd fit alright. hes throwing in 5mm spacers too just incase
dont need spacers coz that offset will fit just fine
Edited by R34P3R
    • Thanks for the quick response mate, and I agree Nismo 555s, Z32 and high flow 2871 in OP6 housing (run by PowerFC) would all be "period correct" and should be a simple, reliable and reasonably quick track car.
    • It is normal for a speedo to read 0-10% high (unfortunately), intended by manufacturers and ADRs (although not in this case) to ensure your speedo does not read low if your tyres are worn. Speaking of which, what size tyres do you have on the rear, and what does they tyre placard say you should have? you can use this https://tiresize.com/calculator/ to determine what % difference that is causing Personally, when I buy tyres for a car I buy a size that will bring the speedo back to being more accurate; it if it reads 5% high I buy tyres that are 5% larger diameter. If you had an electronic speed sender like R33 onwards, the other option is to add a speedo adjuster but that won't work in R32. Finally, you  might be able to find a different sized gear for the speedo sender but that will be limited to what already exists (and I don't know what sizes do)
    • OK...so dumb question to check....do the hi beams actually come on when the push the stalk to engage them (keeping in mind your headlight switch must be at ON as well)
    • Nah it factory manual not sure about ratio but it looks like there’s been some work at the rear
    • so I need a new speedo cable
