  On 25/10/2011 at 7:33 AM, townzy92 said:
well i did a oil seal on my turbo , after putting the new one on cleaning all the oil out of my intake pipes, i cleaned the amf sensor, and soon as i went around the corner and hit boost the the car started spittin black smoke and runnign rough, I cheacked all sensors and borrowed a few off a mate, every sensor was great, i didnt check the cooling temp sensor, so i did research asked about , if the cars cold and i drive it and let idle idles great until car warms up. ( only take 30 seconds if that ) any ways i took the punt and yes it was the cooling temp sensor, the cooling temp sensor reads the car engine temp, any ways when they are f**ked they read a nutral degree ( zero) and as ypu wopuld all know a car engine is a lot hotter lol, so they cts is telling the computer to pump fuel in to make it combust to make the engine warmer,
wheres the cooling temp sensor ??
the ecu only receives input from the o2 sensor once the system reaches operating temp. if the sensor is dodgy its gonna run rich, if you unplug it it will run rich so i dont see the point in that test.
get the car to operating temperature hook up a voltmeter to the sensor, a working sensor should fluctuate between 0-5v.
,but could be dodgy injecor, leaky injector seal, dodgy fpr, dodgy maf, temp sensor, vac leak boost leak, dodgy wiring.
would taking it to a tuning place help or would it be worth trying to find the fault myself ? so far ive spent 600 on splitfires after cartoys said thats what the problem was, i dont want to replace all the sensors in my car before finding the problem and thousands later. Im under the impression that they can hook their computers up n find the faults quickly but i dunno
  • 2 months later...
hey ive just bought another stock o2 sensor, im confused because i have a stock dump pipe and the original o2 sensor is factory yet my replacement o2 sensor is the same as my old one in every way BUT the thread on the new one has a much smaller diameter than my old one so it just drops in the hole and cant be tightened, anyone heard of this before ??
the new one and the old one are identical in shape and size, the plug is also exactly the same but i'd say that there's bout 5mm difference in the thread diameter.
the replacement which is too small to screw into my dump pipe says NGK 205 JAPAN on it, below that on the nut, it says 2E21.
cant see what the old one says on it because it's in the car n i can only ever undo it with a rattle gun
R32s take a sensor with 12mm thread, R33s and beyond take 18mm threaded sensors. It's possible you either have a stock dumppipe from a R33/R34 or it's an aftermarket dump that looks stock?
    • Hi all,   long time listener, first time caller   i was wondering if anyone can help me identify a transistor on the climate control unit board that decided to fry itself   I've circled it in the attached photo   any help would be appreciated
    • I mean, I got two VASS engineers to refuse to cert my own coilovers stating those very laws. Appendix B makes it pretty clear what it considers 'Variable Suspension' to be. In my lived experience they can't certify something that isn't actually in the list as something that requires certification. In the VASS engineering checklist they have to complete (LS3/NCOP11) and sign on there is nothing there. All the references inside NCOP11 state that if it's variable by the driver that height needs to maintain 100mm while the car is in motion. It states the car is lowered lowering blocks and other types of things are acceptable. Dialling out a shock is about as 'user adjustable' as changing any other suspension component lol. I wanted to have it signed off to dissuade HWP and RWC testers to state the suspension is legal to avoid having this discussion with them. The real problem is that Police and RWC/Pink/Blue slip people will say it needs engineering, and the engineers will state it doesn't need engineering. It is hugely irritating when aforementioned people get all "i know the rules mate feck off" when they don't, and the actual engineers are pleasant as all hell and do know the rules. Cars failing RWC for things that aren't listed in the RWC requirements is another thing here entirely!
    • I don't. I mean, mine's not a GTR, but it is a 32 with a lot of GTR stuff on it. But regardless, I typically buy from local suppliers. Getting stuff from Japan is seldom worth the pain. Buying from RHDJapan usually ends up in the final total of your basket being about double what you thought it would be, after all the bullshit fees and such are added on.
    • The hydrocarbon component of E10 can be shittier, and is in fact, shittier, than that used in normal 91RON fuel. That's because the octane boost provided by the ethanol allows them to use stuff that doesn't make the grade without the help. The 1c/L saving typically available on E10 is going to be massively overridden by the increased consumption caused by the ethanol and the crappier HC (ie the HCs will be less dense, meaning that there will definitely be less energy per unit volume than for more dense HCs). That is one of the reasons why P98 will return better fuel consumption than 91 does, even with the ignition timing completely fixed. There is more energy per unit volume because the HCs used in 98 are higher density than in the lawnmower fuel.
    • No, I'd suggest that that is the checklist for pneumatic/hydraulic adjustable systems. I would say, based on my years of reading and complying with Australian Standards and similar regulations, that the narrow interpretation of Clause 3.2 b would be the preferred/expected/intended one, by the author, and those using the standard. Wishful thinking need not apply.
