anyone know the vacume hose setup for standard boost solenoid on a r34 neo is?
From looking around for a while i think it goes something like this:
Intake (air intake pipe) to a T piece, one end to the bottom of the solenoid and the other to the turbo valve?
Intercooler pipe to the top of the solenoid?
Anyone confirm this is correct?
Also i have an after market turbo (hypergear atr43 550hp) will taking out the manual boost controller and using the stock solenoid (for defect sake) be ok?
https://www.sau.com.au/forums/topic/380272-stock-r34-solenoid/
look bud , stock solenoid wont work, Atr43g3 turbo if its new it will open waste gate at 18psi( if not it will open at 15psi ) , If you attach the standard solenoid it may stuff your car, the stock solenoid originally worked off 5 - 7 psi . Honestly if you asking this your going to be like me and stuff your car!! remember original waste gate was about 7 psi
the T piece should be between the cooler pipe and actuator. if your just doing it to get past the pits then run a hose directly from the cooler pipe to the actuator and get rid of the solenoid altogether
The car will run though as the pits are just 5 min away from my house?
So from the cooling pipe is the one one coming from the afm?
Block off the one coming from the intercooler?
At the moment looks like this
    • Sounds like it is rotational in the driveline. CV? Tailshaft CB? Also.....didn't you just pay to have that bit painted and put on the car?
    • Yeah, when I dialled my idle down, given how much time I spent idling at the lights in traffic on my daily commute, the effect on overall fuel consumption was absolutely noticeable.
    • Emissions, fuel consumption, heat, noise, etc. most likely.
    • For me at least the reason why it bothers me is because it's indicative of a deeper problem. And that will nag at me forever. Especially because I have tailpipe emissions testing + evap leak testing every 2 years.
    • WELP. I went to the track, and I suppose it went okay because any time you can drive home is okay. You may notice the car is not on the circuit in this picture. It was about 35C day out in Benalla which means the track was approximately the surface of the sun, probably. Good things, car did not overheat but it _was_ warmer than when I had done track days in similar heat before, I think, I'm not sure - I can't quite remember. Coolant got to ~105 via the ECU after 20-30 minutes of belting it in said heat. Oil got up to 145C in one instance which is pretty crazy due to oil cooler. Pressures were fine. I seem to remember this not getting quite so high before the vents. More HMMMM'ing to be done. On the subject of HMMM'ing, can anyone identify the sounds in the video below, you will know which ones I mean: https://www.youtube.com/watch?v=uj3BkI2cbTc I included some 'normal' sound as a reference for the first minute or so. The microphone in this instance was where the license plate is. It stopped working later in the day which is why my "best example of a lap video (not produced)" had internal audio - Isn't hearable from inside the car. I don't mean the chirping of the un-bedded/badly bedded track brakes which you can only hear while braking... Thoughts, brains trust?
